chesters custom cargo conversion## now for sale##
Postby kickintail » Fri Jul 15, 2011 6:36 am
Don
The walls are covered with a fiberglass wall board found at both big name stores. it is a little pricy and to be honest when it gets real hot inside trailer i still smells a bit like the glue not too bad but i do have a lot of glue being that i glued the vct tile as well. if you use it use a fine tooth saw blade for laminate and wear eye protection
It makes sense if you don't think about it
kickintail
Postby jhanlon » Sat Jul 23, 2011 6:58 pm
What are the black bars things that you used to hold up the bed. I'm new too.
John the Vanner - now with 41 X 48 HF trailer
jhanlon
Postby vreihen » Sun Jul 24, 2011 6:50 pm
jhanlon wrote:What are the black bars things that you used to hold up the bed. I'm new too.
Are you referring to the E-Track on the walls and the wood end sockets for dimensional lumber (aka: 2x4)?
http://www.uscargocontrol.com/Van-Trailer-Products/E-Track-Straps-Tie-Downs
Just the first site that came up in a web search that had the stuff, not a vendor that I've used or who has the best price.....
vreihen
Postby kickintail » Mon Jul 25, 2011 9:46 am
yes it is e track and i did use that vendor
kickintail
Postby kickintail » Fri Aug 05, 2011 9:51 pm
my homemade 50$ awning
[img][img]http://i810.photobucket.com/albums/zz27/kickintail/trailer072.jpg[/img]
kickintail
Postby Wolfscout » Sat Aug 06, 2011 9:36 am
where did you get those two aluminum pieces?
I've been looking for something similiar and found a plastic awning rail on ebay but it's pricey for what it is.
Larry Fulmer, Jr.
CTC 2
Wolfscout
Images: 32
Postby kickintail » Sun Aug 07, 2011 8:26 am
one is just the rain gutter already on the trailer the one with the tarp is awning rail at local rv shop $18 for 12ft with a 1/4 in steel rods to go inside
kickintail
Postby Gadget Man » Sun Aug 07, 2011 10:37 pm
Kickintail:
Try a piece of 1/4 nylon rope instead of the metal rod to hold your awning into the aluminum awning rail.
If you find the right sized rope, you can fold your awning over the rope and slide it into the aluminum track and not have to haul the metal rod.
Gadget Man
My kids may be smarter than me,
But I know more.
Gadget Man
Images: 23
Postby kickintail » Mon Aug 08, 2011 12:47 pm
thanks for the tip i will try the rope
kickintail
Re: chesters custom cargo conversion
Postby Road Doggie » Fri Apr 13, 2012 11:20 am
Great Pictures , nice build. I am new to this first build so Im mgetting a lot of great tips..........what did you insulate your walls with?
Road Doggie
Postby roadinspector » Fri Apr 13, 2012 9:27 pm
I've used the rope several times. It works great.
Dadgum it! I cut that board 5 times and it's still too short!
2001 quad-cab Dodge Cummins 3/4 ton camper special, 16x7x7 CT work in progress toyhauler, 01 HD Ultra Classic, 98 HD Heritage Softail, 88 HD 1200 Sportster. viewtopic.php?f=42&t=51510
roadinspector
Images: 127
Postby Wolfscout » Fri Apr 13, 2012 9:30 pm
Lengths of TV cable work great inside RV rail tracks with a tarp too. Sturdier adn easier to get into the track and work with the tarp inside the rail I think. Your mileage may vary.
Larry Fulmer, Jr.
CTC 2
Wolfscout
Images: 32
Postby roadinspector » Sat Apr 14, 2012 10:14 pm
Wolfscout wrote:Lengths of TV cable work great inside RV rail tracks with a tarp too. Sturdier adn easier to get into the track and work with the tarp inside the rail I think. Your mileage may vary.
:thumbsup: Good info! I'll have to give that a try.
roadinspector
Images: 127
Postby rnjsharp » Sun Apr 29, 2012 9:49 am
wow lots of great ideas on here i do alot of kayak fishing too and am wanting to get a 6x12 trailer to build a toy box out of kinda like yours to keep my kayaks and fishing gear in thanks for all your ideas i will use some
rnjsharp
Re:
Postby Helixpteron » Sun Apr 29, 2012 4:15 pm
Gadget Man wrote:Kickintail:
Gadget Man
What a great idea!
Helixpteron
