I was told sulfur fumes is the problem ?
vreihen wrote:Lead-acid batteries emit hydrogen fumes as they charge, and one need look no further than Lakehurst, NJ in 1937 to know the danger of that.
If you don't want to vent a lead-acid battery, your other option is to spend more money and purchase a gel-cell or AGM battery. These batteries require specialized chargers to prevent damaging them. Here's an article that I just found in Google that explains the various battery options:
http://www.rvtechlibrary.com/battery/bat_agm.htm
eamarquardt wrote:Of the 21,000,000 VW beetles built, I've never heard of one exploding due a buildup of hydrogen gas in the cabin in spite of the fact the cars were virtually air/water tight.
vreihen wrote:With that said, I have personally witnessed a battery exploding on our garage floor when my brother was disconnecting the charger leads and caused a spark. While it didn't explode in flames or with enough energy to knock down the walls, it did have enough force to blow a fist-sized hole through the top and side of the battery and spray acid all over the concrete floor and nearest wall. I wouldn't discount the real dangers caused by hydrogen venting from a charging battery as an urban legend, and make sure that you always charge a lead-acid battery in a well-ventilated location .....
dh wrote:So, your saying we need to vent our coolers incase the sodas explode?
