Johns TearDrop for 5
Postby eaglesdare » Tue Jun 21, 2011 6:50 am
:applause: that is looking great!
Louella
May the foam be with you.
eaglesdare
Camper looks great!
Postby Alfred » Tue Jun 21, 2011 8:32 am
Hey John!
The camper looks great! Keep us posted to the progress! I'm building a camper for 5, too!
AL :thumbsup:
Alfred
Images: 368
Postby J.Heyboer » Wed Jun 22, 2011 12:57 pm
Thank for all the kind words everyone. I am excited to finish up the interior and get cracking on the exterior.
John
J.Heyboer
Images: 84
Postby Boanerges4 » Thu Jun 23, 2011 7:40 pm
Youre doing a great job. Im using the same popup frame. I would really like to know the measurements of your benches if possible. Thanks :thumbsup:
Boanerges4
Postby J.Heyboer » Fri Jun 24, 2011 11:11 am
Boanerges4
The benches that make up the dinnette are 12" Tall by 60" Wide by 20" deep. When the table is lowered between them they will make a 72" by 60" sleeping area.
The bench in the front will be 12" Tall by 72" Wide by 30" deep, this one will also double as a sleeping area.
John
J.Heyboer
Images: 84
Postby J.Heyboer » Sun Jul 24, 2011 6:32 pm
Hey Guys,
I spent the last few weeks painting and sanding.
I put 3 coats of spar varnish on the entire interior of the camper, sanding with 220 grit in between coats.
Front Bench
Center Benches
Kid 2 & Kid 3 testing things out.
Kid 3 relaxing in the rear bunk.
Next I framed up the backrest for the front bench.
Next I glued and screwed a sheet of 3/4" birch ply to the back rest. This board is about 6" taller than the backrest framing. Creating a nice storage cubby.
Next I made brackets for the top bunk/cot. First I cut a 1 1/2" hole using a hole saw.
Next I cut off the corners with a jig saw and then went around the entire board with a router.
Next I bolted in place using two 5/16" bolts and t-nuts.
Heres the poles in the sleeping position.
And in the storage position.
Only have a couple more items to finish of the interior; ac, lights......
Thanks for looking.
John
J.Heyboer
Images: 84
Postby StandUpGuy » Sun Jul 24, 2011 8:44 pm
That is an aweful long span for those poles to make. I think you are going to get a very lot of sagging under weight. It is a very cool idea but have you tested the poles with like 65 lbs on them?
StandUpGuy
Images: 52
Postby J.Heyboer » Mon Jul 25, 2011 7:13 am
I got this idea from others on the forum. It looked like they had used standard closet pole dowels. I will test it once I have the canvas sown up.
I can always upgrade to a larger diameter pole if need be.
John
J.Heyboer
Images: 84
Postby aggie79 » Mon Jul 25, 2011 8:19 am
John,
Those are some fine looking kiddoes you have there! Looks like they are getting anxious to go camping.
The interior of your teardrop looks incredible. I can't imagine how much work it was get it looking that good. I'm in the middle of finishing my doors, drawers, and face frames, and motivational issues. Just thinking about all of the sanding that you did makes my arms and back ache.
Take care,
Postby J.Heyboer » Mon Jul 25, 2011 11:07 am
Thanks Tom,
My kids are way to cute for their own good (and they know it!). Finishing the the walls and ceiling took FOREVER. My hand had cramped into a claw/brush hybrid by the time I was done. But its over now.
Try to stay motivated, as it appears that half the forum (myself included) is eagerly anticipating your next build update. You don't want to let your fans down.
(If I used emoticons, I would have inserted the smile face one here)
John
J.Heyboer
Images: 84
Postby S. Heisley » Mon Jul 25, 2011 6:12 pm
This is a very interesting build, John, and you're doing a good job! Thanks for sharing. :thumbsup: :applause:
Re: Johns TearDrop for 5
Postby Gunguy05 » Wed Dec 04, 2013 12:29 pm
Came across your build thread while looking for family size teardrop designs. Just wondering what finally happened, did you get it finished?
Brian
Gunguy05
Images: 6
Users browsing this forum: Bing [Bot] and 5 guests
