Installing ac
Installing ac
Postby Constrictor » Sun Jul 17, 2011 12:34 am
Are there any threads here with pictures on how you installed ac in a tear? I tried the search feature and didnt come up with much.
Constrictor
Images: 16
Postby Loader » Sun Jul 17, 2011 7:25 am
Constrictor
It really depends on the type of AC unit you have (petcool, 5000 BTU window shaker) and where you want to put the unit. Both types have been installed as a permanent fixture in the trailer and both types have been set on the ground and plumbed into the trailer. Here a few links that include photos of different installs.
http://tnttt.com/viewtopic.php?t=40605
Planovet's install
http://littleswissteardrop.com/air.html
Modified 5000 BTU
http://tnttt.com/viewtopic.php?t=44561
Aggie 79's install (page 35)
http://tnttt.com/viewtopic.php?t=26988
Various installs
http://tnttt.com/viewtopic.php?t=30571
http://tnttt.com/viewtopic.php?t=28475
http://tnttt.com/viewtopic.php?t=17011
The follow links taken from Sdtripper2 at http://tnttt.com/viewtopic.php?t=14725
Side tent air conditioner idea
http://tnttt.com/viewtopic.php?t=9499
Two door method swing out A/C & set on ground and one pipe hole in:
http://tnttt.com/viewtopic.php?t=5136
Tongue & front install:
http://tnttt.com/viewtopic.php?t=12116
http://tnttt.com/viewtopic.php?t=9041
Rear type install:
http://tnttt.com/viewto ... 603#150603
Bob Osborn's in and out window install
http://tnttt.com/viewto ... 157#115157
Hide away A/C
http://tnttt.com/viewtopic.php?t=7084
My first build with petcool outside
http://tnttt.com/viewtopic.php?t=16204
My current build petcool installed inside
http://tnttt.com/viewtopic.php?t=42611
Hope these help you get started!
Earl & Kerry
"Loader"
Loader
Images: 245
Postby Constrictor » Sun Jul 17, 2011 1:26 pm
wow lots of good info, thanks a ton!
Constrictor
Images: 16
Postby planovet » Sun Jul 17, 2011 8:26 pm
That's a pretty comprehensive list Loader :thumbsup: :lol:
ImageMark (& Cindi)
planovet
The Cat Man
Postby the other side » Tue Jul 19, 2011 9:13 am
How can I bookmark that list that loader wrote, and how can I access the bookmarked list after it is bookmarked?
the other side
Images: 10
Postby SeaFlea » Tue Jul 19, 2011 10:17 am
In Firefox you'd bookmark the page; right click then select "bookmark this page". It will be added to your list of bookmarks...
In IE you'd save the page as a "favorite"; right click then select "add to favorites".
Charlie
SeaFlea
Images: 10
Postby Shadow Catcher » Tue Jul 19, 2011 11:14 am
Also, adapting a 5000 BTU http://tnttt.com/viewto ... ht=hacking
Postby the other side » Tue Jul 19, 2011 2:13 pm
Thanks Charlie!!! I added it to my favorites since I know how to use that. I didn't realize "favorites" would recognize the one page, I thought it would recognize the entire site!!! Thanks loads!
the other side
Images: 10
Postby SeaFlea » Wed Jul 20, 2011 8:21 am
You're welcome! :thumbsup: Glad I could help!!
SeaFlea
Images: 10
Postby Synthesis » Wed Jul 20, 2011 9:40 am
Here is my AC attempt as well. :)
http://tnttt.com/viewto ... 698#847698
It isn't finished yet, but still a work in progress. :)
Synthesis
Postby bushido41 » Thu Jul 28, 2011 7:09 am
Hello Everyone,
Here is my attempt to cool down my TTT here in Florida. So far we have been very successful. Image
At the beginning the AC could not keep up and the problem was the return volume was too little, because I covered the return and only had a 4 inch hole. I removed the cover and now works great at 90 plus temperatures.
Cheers,
Ed
K4BQN
bushido41
Images: 57
Postby Constrictor » Thu Jul 28, 2011 8:34 am
do any of you have any issues with the bouncing of the trailer during transit breaking or shortening the life of the Ac unit??
Constrictor
Images: 16
Postby mvperini » Thu Jul 28, 2011 8:48 am
here is our AC install
http://tnttt.com/viewto ... highlight=
mike
1947 Kenskill teardrop kamper 4X10>
1951 Boles Areo 16ft Canned Ham>
1956 Roadmaster 20ft> Restored
1959 airstream 18ft restoration complete
1953 Pontiac house car
mvperini
Postby Shadow Catcher » Thu Jul 28, 2011 12:57 pm
I did not want to block the use of a door and wanted it detachable. I solved the problem of the return air by installing a bilge blower which works at less than half speed sufficiently.
