Should the axle (torsion in this case) be bolted to the frame or welded on. I have seen it both ways.
Jerry
Ashleymeadow wrote:I see it, but I don't see it! I like the idea, but I can't see where the bolt heads are. If it is under that 1/8" plate, you much have drilled out a hole in the frame!
Thanks,
Jerry
Okay, now I understand. I think that is how I will do mine.
Thanks
