roof and hatch construction
Postby tathead41 » Sat Aug 06, 2011 10:02 am
:oops: ive got another newbie ? for u very kind people :) :thinking: of a wierd idea for the roof and hatch "leaking" thing .....in a normal house roof they use a tar like paper before puting on shinges .......has any one esle thought of useing this idea on thier teardrops? and if so ..howd it work? will it work? and any thoughts on this would b helpfull :) :) thankyou for yr time and replys ;)
tathead41
Postby dh » Sat Aug 06, 2011 11:19 am
Let me start by saying, I'm not a roofer. I have built a few custom dog houses/play houses though, and have applied 3 tab or shake shingles to them all, and have helped on a shake roofing job. I've only used roofing felt under shake shingles. It is put on so the next row overlaps on top of the previous row, and roofs have minimum pitches so the water runs down, and doesn't sit there... I'll let you make up your mind from here.
dh
Postby madjack » Sat Aug 06, 2011 2:36 pm
...and what are you planning to put over that felt paper...felt paper goes under 3tab(and other type) shingles to give additional waterproofing...the best roofing material is a one piece covering such as aluminum or EDPM rubber and requires nothing underneath it...............
madjack 8)
