I think I might be on to something...roof covering idea
Postby eddie6775 » Mon Jul 04, 2011 4:06 pm
Hi everyone, I've been carefully planning my impending build of and I've learned that other than the 3/4 plywood for the floor, finishing the roof to be weather tight is going to be the single most costly thing. So any way, the other day I was helping my boss unload this big canopy and thought; maybe I can use this material for my roof coating! Big white tarps are easy to get on a budget. maybe...just maybe i can glue it down to primed wood with liquid nails smeared evenly and then trim the edges flush before installing molding. I'm trying to avoid seems. Does this sound possible? :twisted:
eddie6775
Postby Catherine+twins » Mon Jul 04, 2011 4:12 pm
This is discussed in the Foamy area down below Build Journals. We are using it as a strengthening skin over the foam construction, but it is also supposed to be water proof.
Catherine
Catherine+twins
Images: 124
Postby eddie6775 » Mon Jul 04, 2011 4:34 pm
Thanks Catherine! I'll be down below reading then..lol.
eddie6775
Postby rowerwet » Wed Aug 10, 2011 6:02 am
http://tnttt.com/viewto ... highlight=
I used painted canvas about the same idea, was just wondering about tyvek instead of canvas...
rowerwet
Images: 521
Postby Synthesis » Wed Aug 10, 2011 10:11 am
You can always look into EPDM (Rubber roofing).. Check any RV Repair Center, or any mobile home repair, and roofing contractors.
I paid around 40 dollars for enough rubber roofing to do two 5x10 campers.
The adhesive was another 30 bucks.
Synthesis
Users browsing this forum: Google [Bot] and 3 guests
