bobhenry wrote:The bending would be deminished because you now have a tensioned member. The wood fiber in the pole is now tensioned much like a guitar string. You have transfered the load somewhat into the walls themselves.
I agree that the load could tear out the pole support sides as the pin is also being side loaded and is attempting to bend with the pole so it could lever the fibers in the support block and split it like a wood wedge in a log.
Always something to think about huh?
StandUpGuy wrote:Well I fail to see how the pins would stop the poles from bowing. I would think the bowing would still happen and simply bend the pins and or tear the hole the pins are dropped into on the cradle.
Your pin idea is a fine suggestion.CarlLaFong wrote:StandUpGuy wrote:Well I fail to see how the pins would stop the poles from bowing. I would think the bowing would still happen and simply bend the pins and or tear the hole the pins are dropped into on the cradle.
You're talking about a child, not a hippopotamus. If you drill the cradles and the poles and use 7/16 or 3/8 steel pins, they will not bend. Period. They will also not tear out of the sides unless the cradles are made of some cheepo thin material. I never cease to be amazed, when given a simple effective solution to a problem, the number of naysayers that will emerge and predict doom and death and suggest various expensive, heavy, cumbersome and Rube Goldberg solutions. To those folks I say, "Fine, whatever works for you."
Yep that would do it. I am thinking the OP is going to see how it goes as is because he already has the cradles complete and the poles purchased and cut. He could always later switch it out.Deryk the Pirate wrote:Forget round....a pair of 2x3's could have the edges rounded a bit and would easily support a kid's weight
bobhenry wrote:And no one mentioned the possibility of a fire !
Sounds like a plan.boatyardgirl wrote:WOW I learned exactly what I am going to do here! I did a search just for canvas bunks and here was the answer![]()
I love the idea of the pin and the 2 by 3 (square end)
BUT my daughter is 100 lbs( & 17 years old) so I think I will go with 2 by 4s set in pins and a square cut in the cradle (wont roll out). I will be using heavy duty outdoor grade canvas set with pounded grommets. I hope to be able to pick up the edge roll it up and fasten it to the wall when we dont need it. If I thought I needed it I could" hang" the edges with wire. Thoughts? Amanda
Users browsing this forum: Bing [Bot] and 5 guests
