Galley offset
Galley offset
Postby CliffinGA » Sun Aug 14, 2011 2:02 pm
Ok screwed up again and did not cut the 3/8" notch before mounting the walls and glueing them. What is the best way to cut it once you havbe mounted it? I bought a 3/8" x 2" flush trim bit with a bearing but not sure how to make a guide to use to cut the notch. Any help would be appreciated.
Cliff
My Build:
viewtopic.php?f=50&t=42628
CliffinGA
Images: 207
Re: Galley offset
Postby toypusher » Sun Aug 14, 2011 4:00 pm
CliffinGA wrote:Ok screwed up again and did not cut the 3/8" notch before mounting the walls and glueing them. What is the best way to cut it once you havbe mounted it? I bought a 3/8" x 2" flush trim bit with a bearing but not sure how to make a guide to use to cut the notch. Any help would be appreciated.
Cliff
You could get a 3/8" rabbiting bit and do about 1/2 of it and then us the trim bit to cut the rest. Just a thought. You could also mark a piece of scrap to the exact contour that you have and then draw a parallel line that is offset 3/8" and then cut on that line. Then you can put that piece up against you tear side and us the flush bit - following your scrap piece. Hope that makes sense to you. It made sense when I was typing it anyway! :lol:
toypusher
Images: 324
Re: Galley offset
Postby LDK » Sun Aug 14, 2011 4:29 pm
Cliff
Hey Cliff
He is right. You don't need a guide you can use a 3/8" rabbeting bit to make the first pass and then use your flush trim bit to take out the rest of the material. I think using the router is the best way to cut your hatch offset.
LDK
Postby CliffinGA » Sun Aug 14, 2011 10:04 pm
Thanks guys for the responses and I thought about doing that as Karry had sent me the pics of how he did his. I have a bud who is willing for me to treat him to dinner next weekend and he will bring his bits and do just that. I did go ahead and make a template of the sides so I can make the spars for the hatch.
Cliff
My Build:
CliffinGA
Images: 207
Postby aggie79 » Mon Aug 15, 2011 7:57 am
Hi Cliff,
When I got to this point in my build, I was a little intimidated. But thanks to all of the help I received, like the responses to your post, I was able to make the notch with little fanfare.
For the benefit of others that haven't seen this technique before, here are a few pictures and sketches.
The first step is to use a rabbet bit to cut the notch to the depth you want.
The second step is to remove the remainder of the material with a template or pattern bit.
Take care,
Postby dh » Mon Aug 15, 2011 10:58 am
Do you leave the ends of the cuts rounded or chisle them square?
dh
Postby Larry C » Mon Aug 15, 2011 11:56 am
aggie79 wrote:Hi Cliff,
Take care,
Tom,
Is there any reason not to do the notch cutting on the bench before the walls are installed? That's what I plan to do unless there's a reason not to??
Larry C
"If its worth doing it's worth doing Light"
http://www.tnttt.com/viewtopic.php?f=50&t=35852
Larry C
Images: 78
Postby aggie79 » Mon Aug 15, 2011 12:08 pm
dh wrote:Do you leave the ends of the cuts rounded or chisle them square?
DH,
I ended up cutting the ends square and left room for a strip of weaterstripping perpindicular to the weatherstripping along the hatch edge.
Take care,
Postby aggie79 » Mon Aug 15, 2011 12:15 pm
Take care,
Tom,
Larry C
Larry,
Cutting the notch on the bench is easier. The reason I didn't is because my hatch framing follows the "pre-notch" profile of the galley walls. I framed my hatch in place to keep things lined up.
Then I removed the hatch and cut the notch.
Take care,
Postby dh » Mon Aug 15, 2011 2:27 pm
I'm thinking that even on the bench the router would still be an easier way to go.
dh
Postby Larry C » Mon Aug 15, 2011 4:21 pm
Take care,
Tom,
Larry C
Larry,
Take care,
I see....
This could be a problem if one didn't plan ahead! In my case it shouldn't be an issue. My hatch is only a half hatch, and does not go all the way to the floor. I should be able to follow the wall profile even with the notch pre-cut, but I'm glad I asked. :thumbsup:
Thanks...
Larry C
Larry C
Images: 78
Postby CliffinGA » Mon Aug 15, 2011 7:48 pm
Thanks Tom for the explanation and giving me another idea. I'll start the hatch on friday night to get it exactly to side profiles before I cut out the notch. It should make it easier to get all the pieces to fit really well.
Thanks all for the help guys! :thumbsup:
Cliff
My Build:
CliffinGA
Images: 207
Postby aggie79 » Mon Aug 15, 2011 8:18 pm
I just thought of another reason to cut the notch after the walls are up. When I installed the outer plywood skin I let it "run wild" past the edges of the sidewall. Then I used a pattern bit and router to trim the edges. If I had notched the sidewalls first I would have had to be careful to not let the bearing of the pattern bit get into the notch.
Users browsing this forum: olsalty and 7 guests
