Charging Battery Between Trips
Anything electric, AC or DC
Postby jerry101jlh » Wed Aug 24, 2011 12:48 pm
Read a post on another forum that batteries should be kept charged between trips. Now the answer to that question may be on here somewhere, but don't see it. We have a small gel cell and can get a battery tender fairly cheap, but is it wise to keep the battery charged 24/7 or let it die completely and get a full recharge via the TV while on the way to wherever?
jerry101jlh
Postby dh » Wed Aug 24, 2011 1:01 pm
Battery maintainers are designed to do just that, maintain a battery while stored. Some use them like a power supply successfully, but they deliver a maintenance charge and have a built in charge controller to prevent overcharging and just keep it topped off. IMHO this is a mutch better option than letting the battery die completely down.
dh
Postby GuitarPhotog » Wed Aug 24, 2011 1:25 pm
Don't let a lead acid battery, whether gel cell, AGM, or conventional wet cell, go completely dead.
Doing so will damage the plates making it difficult/impossible to recharge.
Always keep the battery more than 50% charged, with fully charged being better for the battery's health.
<Chas>
GuitarPhotog
Images: 55
Postby jerry101jlh » Wed Aug 24, 2011 2:37 pm
Appreciate all the input as this is a subject that has never crossed my mind. Trying to read in all this advice and take what applies. Yes, know you do not want to leave a battery fully discharged or dry. In my particular situation the manufacturer says 40 minutes of being hooked up to the TV while running will completely recharge the battery. There is no draw on the battery while parked between trips. Any trips taken most likely will be longer than the 40 minutes so returning home and putting away the trailer battery should be fully charged. Time between trips most likely would never be more than 60 days and unlikely a battery in good condition would fully discharge in that time period if no draw on it. A battery tender might be a good idea and not cost prohibitive, but most likely not needed. So does what I say here make sense?
jerry101jlh
Postby Shadow Catcher » Wed Aug 24, 2011 3:39 pm
Best source I have seen for over all info is http://www.batteryfaq.org care and feeding of a battery is important if you do not want to be buying another one soon.
Postby Richard A. » Thu Aug 25, 2011 12:33 pm
jerry101jlh wrote: Time between trips most likely would never be more than 60 days and unlikely a battery in good condition would fully discharge in that time period if no draw on it. A battery tender might be a good idea and not cost prohibitive, but most likely not needed. So does what I say here make sense?
If I were you I would get the Battery Tender (brand name).
I have a 12v "marine" battery and I charge it EVERY week when not in use. For the winter I will remove it, bring it inside and put it on something similar to the Battery Tender.
Batteries "self discharge" when not being used. The longest battery life will be when the battery is kept at full charge. A Battery Tender is cheap insurance.
Richard A.
Boston, MA, USA
2008 Little Guy Silver Shadow
Richard A.
Postby bdosborn » Thu Aug 25, 2011 8:12 pm
Sulfation begins on even slightly discharged batteries in as little as a day. Batteries should be recharged as soon as possible and should be on a maintainer 24/7 when not in use for maximum battery life.
Images: 806
Return to Electrical Secrets
