Does anyone know how to get a jack on the tongue that won't twist? Due to the A-Frame design of the tongue, the jack I have causes the unsupported side of the tongue to droop.
Perhaps a scissor jack under the A-Frame crosspiece?
slowcowboy wrote:zack. I see what looks like a button on tonnoe cover on the roof of your teardrop....
Deryk the Pirate wrote:Slow, I like the hitch you used. Any closer pictures of how you modified it to fit your HF trailer?
thanks
deryk
dh wrote:How elaborite do you wanna get?
You could put a plate accross the tongue members right behind the coupler and mount an A-frame jack in the plate...
101camper wrote:Another solution - install a 1/4" aluminum plate to the tonge crossmembers and mount a regular trailer jack. I had to shorten the jack with a hacksaw by 4" to obtain the desired ground clearance. The jack is positioned far enough aft of the coupler to be clear of my cars hatch and pickup's tailgate when opened, with the trailer hitched up.
dh wrote:Just curious, any reason you went with aluminum over steel?
