campmasterk wrote:Hey Cliff, no Im gona shave it off I was just so happy about it I had to take a picture as soon as it was on. As for the finish Im gona epoxy seal, then a couple coats of STIX primer. Its a waterborn urethane, and its sands great. Then I got this trick stuff From Ben Moore called Waterborn Urethane gloss finish. It also has a clear that I am going to use. Its just experimental for me I like to try new coatings. Its my business. I did some testing of this system and some phone calls to the paint gods and it should be very durable and flexible. We shall see.
campmasterk wrote:As a joke I think I might make up a little bed of silk tuck n roll. ehhhh maybe not.
campmasterk wrote:Can somebody tell me if there is a standard gap between the door and frame if you are using Grants trim for the frame and t mould for the door?
