Quick, easy Butt Joint connectors
Postby cracker39 » Wed Feb 22, 2006 1:43 pm
I don't remember what these connectors are called, but I think they were intended to mend wood framing on screen doors. I probably bought these over 20 years ago and they have just been sitting around in a jar waiting to be needed...and now, they're so happy that they are needed and finally being used!!!
I discovered them in my workshop stuff, and am using them to fasten framing pieces together as I construct my sides. They work great in pine or spruce (soft woods), but I doubt they would go into oak so easily. You just hammer one or two connectors into the wood to fasten them together. As you can see from the inset close up, they are wavy so they won't pull out easily. The're working fine for me.
Dale
cracker39
Images: 233
Postby halfdome, Danny » Wed Feb 22, 2006 3:32 pm
They are corrugated fasteners. They use to be associated with the construction of orange crates but cardboard boxes are used now. Not the type of fastener I would recommend.
halfdome, Danny
*Happy Camper
Images: 252
Dale be careful
Postby Guy » Wed Feb 22, 2006 3:42 pm
Dear Dale,
Corrugatoed fasteners were designed for crates and frames to be used on mitered edges and not as you are using them, especially since you are using them in opposigte directions and creating a narrow break which can pull out the whole trapezoid created by the angles. T way you could use themis to reverse the angles so that the trapezoid is larger on the bottom of your photo than on the top and extending out past your vertical frame.
Regards,
Guy
Guy
Images: 44
Postby Ira » Wed Feb 22, 2006 3:46 pm
Boy, am I glad I don't have any of those…
Because I don't know WHAT the heck you guys (not just Guy) are talking about.
Here we go again!
Ira
Forum Storyteller
Images: 118
Postby Chris C » Wed Feb 22, 2006 4:21 pm
I was going to really let Dale "have it" until I realized he wasn't connecting anything of structure! All he is doing is connecting the framework for inside his walls..............and all of that will be glued to the plywood on both sides (I'm assuming), so no matter how he connects them, they should be alright. Now it would be an entirely different matter if he were using those to make a faceframe for the cabinets.
Chris :D
Chris C
Postby cracker39 » Wed Feb 22, 2006 5:20 pm
Thanks, Chris...you got the picture. No structural strength is required where I'm using these fasteners. They really hold the pieces together while the glue dries. I have glued and clamped or weighted all of the framing to the outside skin, and when I can get the side upright, I'll add some 3/4" screws from the outside through the skin into key framing pieces for insurance (i.e. sheet joints and a couple of horizontal pieces front to back). The windows and door will have screws through the skin into framing as well.
Dale
cracker39
Images: 233
Postby EZ » Wed Feb 22, 2006 5:55 pm
Those things are a great idea! Most of the areas where they would be used are covered in plywood resulting in a huge corner gusset which will be really strong. Way faster and easier than a pocket hole for the proper application. I used staples to hold the 1 X's but they present their own problems (not countersunk, only holding 1 side, etc.). If I had thought of these, one at each joint would have worked perfectly. Maybe I can use some for the door framing and the bunk frame. Thanks for the tip!
Ed.
EZ
Images: 72
Postby angib » Wed Feb 22, 2006 6:21 pm
Dale,
An excellent application of a simple product. My compliments to you.
Even my engineering instructor would have approved (not something he did often, as I remember....) - he was the one who taught me that: 'An engineer is someone who can do for a quarter what any fool can do for a dollar'.
I think this guy is using those connectors too:
Andrew
PS Yes, that saying above has been converted to American units - could your fancy Mac have done that, Ira?
angib
5000 Club
5000 Club
Images: 231
Postby cracker39 » Wed Feb 22, 2006 9:06 pm
angib wrote:Even my engineering instructor would have approved (not something he did often, as I remember....) - he was the one who taught me that: 'An engineer is someone who can do for a quarter what any fool can do for a dollar'.
Andrew
Thanks, Andrew. I guess I just try to find easier and cheaper ways to doing things. I'm a tinkerer at heart. I sometimes go out of the way to do things differently. They're not always the best way, but they're my way.
:wacky
Dale
cracker39
Images: 233
Postby gman » Wed Feb 22, 2006 9:37 pm
Ira wrote:Boy, am I glad I don't have any of those…
Ira, I'm just glad it wasn't a Brokeback Mtn kinda post.
Junk is something you've kept for years
And throw away three weeks before you need it.
gman
Postby DrJerry » Wed Feb 22, 2006 9:38 pm
...and just WHAT may I ask, is wrong with a MAC? :shock:
Jerry
Watch and laugh as an Engineer with an advanced degree attempts to build a Tiny Travel Trailer:
http://www.angelfire.com/blog/weekender ... weekender/
DrJerry
Postby Nitetimes » Thu Feb 23, 2006 12:13 am
angib wrote: 'An engineer is someone who can do for a quarter what any fool can do for a dollar'.
I do believe that's usually stated the other way round.... 'An engineer is someone who can do for a hundred dollars what any fool can do for a dollar'. :lol: :lol: 8) :lol: 8)
Rich
- Thomas Jefferson -
Nitetimes
7000 Club
7000 Club
Images: 194
Postby madjack » Thu Feb 23, 2006 12:27 am
Nitetimes wrote: I do believe that's usually stated the other way round.... 'An engineer is someone who can do for a hundred dollars what any fool can do for a dollar'. :lol: :lol: 8) :lol: 8)
now that is how I always heard it ;) the other must be an engineers story...
madjack :lol:
Postby Big Guy with a Little Guy » Thu Feb 23, 2006 12:29 am
A butt joint connector?
I'm glad you posted a photo because I was picturing a shiny stainless steel clamp and a tube of super glue in the hands of a proctologist.
An image of Jack Elam just flashed into my mind...
Not So Tiny Travel Trailer Dude
Users browsing this forum: Google [Bot] and 1 guest
