dh wrote:Good point about the illuminated switch. However, I have yet to come accross one that wasn't marked on the body as to what went to what terminal. SPDT and DPDT switches usually lack the markings.
dh wrote:Wasn't trying to argue or pick a fight Dale, just explaining that I based my reply on the stated fact in the OP that the switch had no markings on it.
BTR22 wrote:
"This switch can be on in both positions, switching on a separate device in each case. It is often called a changeover switch. For example, a SPDT switch can be used to switch on a red lamp in one position and a green lamp in the other position.
A SPDT toggle switch may be used as a simple on-off switch by connecting to COM and one of the A or B terminals shown in the diagram. A and B are interchangeable so switches are usually not labelled."
I will probably cover up the unused connection with spade connector and tape it up. Does this sound correct?
