lil vardo 2
Postby Deryk the Pirate » Mon Aug 01, 2011 6:17 pm
Yeah I'm real happy finding the insulation, same I will be triming it a bit to fit between the supports.
To square the frame I took off the 2 2x4x10 on each side and loosened the trailer up and started in the back, layed a piece of 3/4" 4x8 plywood and started clamping it down to keep the frame square. Took some work but I got it pulled in a lot closer then it was...looks good now.
I'm goin tent camping unless the weather is too hot/humid, or the rain they were talkin about shows up....personally I would rather be workin on the vardo...but haven't seen these friends since the fall since they are a 3 hour or so drive, and I've been guilted into going lol...
Deryk
Deryk the Pirate
Images: 158
Postby Jst83 » Tue Aug 02, 2011 7:54 am
Deryk the Pirate wrote: Im debateing putting the door on the back side since I can make more of an overhang over the door and not be worried about the wind grabbing it like it would in front.
Which way have you decided to go I'm drawing up some vardo plans and was thinking the same thing, that would make a heck of a scoop pulling it into the wind.
Keep up the good work I'll be watching and learning :thumbsup:
Jst83
Images: 215
Postby Deryk the Pirate » Wed Aug 03, 2011 9:37 pm
Well I decided to stick with my original plan with the door faceing the tongue so i can have a tiny deck with a galley on the backside... makes the most sense to me.
No work this weekend goin tent camping with friends... next week Im hopin to get some walls up!
Deryk the Pirate
Images: 158
Postby absolutsnwbrdr » Fri Aug 05, 2011 7:05 am
Can't believe you're already building number 2!! I'm jealous! I know that I learned a lot building the first one, and I'm sure you were the same way. Looking forward to seeing this one too!
Zach
Coming Soon...
absolutsnwbrdr
Images: 412
Postby Deryk the Pirate » Sun Aug 07, 2011 9:28 pm
Zach, I couldnt believe the first one sold as fast as it did lol. Yeah Ive learned a few things, and still am lol... and already thinkin about tryin a fullsized bowtop vardo (But i really wonder if there hard to tow)..Im just crazy...too much time on my hands lol
Well the forcast was bad for camping...so I went down to work on the vardo. Image Image Image
I was raceing a weather front so didnt take much pictures. Its looking real boxy now, probably wont get the arches cut next weekend, although I really want to...will see.
I got the door made, 28" wide by 39.75" tall, insulated it while building it. Hopefully next weekend the door will be in and the last outer wall done. The mdo plywood looks like cardboard in the pics lol. I did get to epoxy the edges yesterday but cant wait till the roof is done and its all painted and protected from the elements.
Deryk the Pirate
Images: 158
Postby Deryk the Pirate » Sun Aug 14, 2011 9:53 pm
Well got 1 short day of work done before the rain came and killed the weekend. I also saw 2 of my friends in a local production of Cinderella saturday nite...was nice to get out for a night!
My friend Connor was at Pennsic, so I got to cut and plane and sand the arches myself. Wasnt so bad till I think I killed his old belt sander...guess I will be buyin him a new one...lasted about 3 minutes till it started smoking lol.
Image I ended up triming an inch off each side, was just too wide for what I wanted.
Image Lookin less boxy, more "vardo'ish" lol
Image Image The purlins are 2x4's cut in half screwed and glued. I added 1 on each side on my side walls screwed and glued in place, so it should help hold the roof down. There is about a dozen 4" screws and titebond 2 holdin each arch in place.
Image All closed up to protect it from the monsoon we got all day sunday...sigh
Hopefully I will have the plywood roof on next weekend, and whichever way I decide to go metal or epdm by the end of the month. Im a bit torn, might do the metal roof, a bit more costly but would be less subject to damage then the epdm...any opinions?
thanks
deryk
Deryk the Pirate
Images: 158
Postby Woodstramp » Sun Aug 14, 2011 10:07 pm
Deryk,
The arches are giving it the vardo-y-ness. :)
I was thinking about an idea while you were doing the other trailer. If there was a way to get some kind of hub caps for the wheels, paint flat black and adhere some faux wood spokes to the the caps. If it could be done without throwing wheel balance out the door, that is.
Woodstramp
Postby Deryk the Pirate » Mon Aug 15, 2011 9:45 am
I've thought of looking for a pair of small wagon wheels and take some black cloth to cover the existing tires... but that's worriees for another day lol
Deryk the Pirate
Images: 158
Postby droid_ca » Mon Aug 15, 2011 10:30 am
what about painted hubcaps that might work your trailer is looking really good ae you building a porch on the back of it if so how do you think that will affect the weight of the trailer keep up the good work
“Fide Canem”
viewtopic.php?f=5&t=52816
droid_ca
Images: 176
Postby Deryk the Pirate » Mon Aug 15, 2011 11:34 am
Thanks Droid, its starting to take shape, which makes me happy. The back "porch looking " area is where my galley is going to be, just haven't started it yet. Need 2 more sheets of mdo plywood to build it. I am planning a small porch by layin some. Cedar over the tongue area. Wish money wasn't holdin me back so lol...
Deryk the Pirate
Images: 158
Postby Woodstramp » Mon Aug 15, 2011 1:28 pm
I like Droid's idea for just painting spokes on hubcaps. That gives the look, but no balance troubles.
Deryk,
Don't make this one look as good as the other one. Another friend (with greenbacks) will keep you from actually using it. :lol:
Woodstramp
Postby Deryk the Pirate » Mon Aug 15, 2011 8:13 pm
Woodstramp wrote:Deryk,
lol yeah right.... Well if all goes well the end of the month I might be comin into an extra paycheck, might buy another trailer and start on 1 to sell so I can keep this one. :twisted:
Deryk the Pirate
Images: 158
RE: "LiL Vardo 3"
Postby mezmo » Sat Sep 03, 2011 9:15 pm
Hi Deryk The Pirate,
We all "know" you'll just have to do another build when you finish the
LiL Vardo 2. So here's some links to a small BowTop style Vardo
that was done as a thesis project,for inspiration.
http://tinyhouseblog.com/tiny-house-concept/protostoga/
http://tinyhouseblog.com/tiny-house-con ... ga-update/
http://tinyhouseblog.com/stick-built/pr ... -interior/
The aluminum roofing idea is very interesting.
Cheers,
Norm/mezmo
mezmo
Images: 194
Postby jbyrd » Sat Sep 03, 2011 9:43 pm
It's coming together nicely, I really like the vardo style and thought about building one but was really unsure about the wind drag issue towing it.
Look forward to seeing it finished.
Til later, See ya
Jeremy
My build journal #1 "SOLD" : viewtopic.php?t=45945
my build journal #2 "SOLD": viewtopic.php?f=50&t=59216
jbyrd
Images: 172
Postby Deryk the Pirate » Mon Sep 05, 2011 6:26 pm
Norm, Yeah Ive seen the photo's of it and it is sharp, but 600 hours of labor, lol I would need a garage near where I live to work on it, my friends house is too far for dailey commutes back and forth lol. I have had some thought of useing bendy plywood and fiberglassing it to seal it then canvas overtop to just make it look "period" All insulated to make it a more solid structure. If things work out right this week for a change then will see.... but Im so far behind on my current vardo. Most of july and august it rained on the weekends, my only time off to be down at my friends shop. Get a great holiday weekend and I got an infected boil lanced friday and spent most of the weekend sleepin and poppin hard core anti biotics.... always something... thats just life.
Thanks Jeremy! Yeah I just love to look of the vardo's. There will be a certain amount of drag, but it depends on your vehicle. My original plans were for this one to be narrower and shorter in height then my first to be less of a strain on my old pt cruiser. With that gone and a larger tow vehicle I decided to go with 75" exterior width (6 foot inside)to squeeze a bed in across the width to give my a tiny parlor inside. Original width was about 22" less lol.
My Rav4 has a 3500 lb tow capacity and Im guessing I will be a little over a 1000lbs, so it can more then handle it. I am gonna be addin airbags (if I can find them) to stiffen my rear end a bit. When I hooked it up to move it to my friends backyard for Irene, was a bit tough gettin the tongue jack to open properly to crank it off the ball, was about an inch too low.
Or change the reciver and use a center mounted jack with no wheel...or try a 3" raised receiver instead of the 2" I had... always so many decisions (and money!) lol
Deryk the Pirate
Images: 158
Users browsing this forum: Paintsalot and 2 guests
