Hi stugpanzer,
First off - Welcome to the T&TTT forum. A great friendly place.
There is one TD on the forum that basically used wood for it's "chassis"
with the half-axle style torsion axles and the hitch bolted to the wood. I
can't recall who did it though at the moment. Hopefully someone else has
a quick link to that build for you.
The Design Library:
http://www.angib.pwp.blueyonder.co.uk/t ... tear00.htm
has a very minimal steel frame in "The Ultralight Chassis" [at the
bottom of the page]. It depends on the 'torsion box' that a well put
together wooden TD becomes once it's all glued together. I don't
know how much of a torsion box a TTT's body would be since it is
larger and generally has more openings. Some of the early TTs from
the 20s and 30s did use wooden chassis, but they were held together
with carriage bolts and such - an extension from horse drawn wagon
and carriage technology/methods etc. so look into that some too.
I'd should think that if you do use wood as some of the vintage plans
have done, it should be oak or ash or some other tough, strong and
somewhat flexible hardwood. Look for the kinds that are also rot
resistant. I don't know if some of the rot resistant softwoods would
be strong enough. You'll have to research the various wood's qualities
and traditional uses etc..
I would stay away from any Pressure treated wood for use in the build.
Even though the "new" style PT doesn't have arsenic it still has other
chemicals you don't want to be breathing, especially in a smaller
confined space like a TD/TTT sleeping area. Don't chance it. Another
HUGE drawback to the new PT wood is that the QUALITY IS TERRIBLE. I
just recently [last year] finished a @13x21ft deck on the back of our
house. The new PT looked OK enough when delivered. But every stinkin'
board - some more than others, but still every deck board and 2x framing
materials either twisted, cupped, bowed etc. w/ huge differences between
PT wood from different lots. God help you if it sits in the sun [especially
the HOT southern sun] before you use it. I do not think it is dimensionally
stable enough for the more precise framing a TD/TTT needs. I had one
12 ft 2x6 joist that was straight for the first 1/3, bowed up 4in off center
the next 1/3 and bowed down 4in from center on the last 1/3! Some did
ease back some when they got wet a little, but I had to use pipe clamps
to force/nudge EVERYTHING into place as I built the deck. Thankfully the
hundreds of screws used to hold it together has kept it pretty much in
place. And this was using the more expensive grade of PT wood! I have
deck boards from three different lots [basically from three different
lengths as purchased] and each has a noticeably different expansion and
contraction rate. Do yourself a huge favor and avoid PT wood for the TD
build. You will be sorry if you use it!
Otherwise, good luck on the build! Ha!
Cheers,
Norm/mezmo
