Thanks Madjack, I will go withthe 60#.........Your gasless struts are NICEmadjack wrote:...maybe but I would go redundant and use at least 60# struts so that when(not if) one fails the other will keep the hatch off of your head...you may want to look at the two sticky's for my gasless gas struts and Steve Cox's hatch struts...
Thanks Mike, Your right, heavier struts are in order. The first time the hatch weighed 40#, (from the center of the hatch). It was weighed again ( this time closer to the hinge) with a weight of 60#mikeschn wrote:Gas struts are still an art to me. (Cause Andrew didn't turn all the strut information into a spreadsheet yet!)
I tried 90# struts, and they were too light. Then I went back to the auto parts store and exchanged them for 120# struts. They worked perfect.
Now you are probably wondering how heavy the hatch is. I don't know. I haven't taken it off to weigh it. Maybe Steve Fredrick knows? Steve?
Thanks surveytech, I must have missed your post somehow.........Yes the closer to the hinge you are, the more force is needed in a gas strut.......I learn something NEW every day.surveytech wrote:there is a formula somewhere that will calculate the pounds of force needed for gas struts.
But in general, the closer you are to the hinge the more force you need to open it.
seahorse wrote: They are an art to me also. ... will have to attatch some temporary supports to the sides (so they don't look like SWISS CHEESE )
mikeschn wrote:okay, here's my swiss cheese...
P.S. Notice all the plugged holes in the side wall...
P.P.S. And that big hole in the hatch. That's where I tried to drive a shock thru the hatch. I guess I'm lucky it didn't go thru the outer skin.
mikeschn wrote:P.P.S. And that big hole in the hatch. That's where I tried to drive a shock thru the hatch. I guess I'm lucky it didn't go thru the outer skin. Any suggestions how I can repair that?
Mitheral wrote:mikeschn wrote:P.P.S. And that big hole in the hatch. That's where I tried to drive a shock thru the hatch. I guess I'm lucky it didn't go thru the outer skin. Any suggestions how I can repair that?
Pair of butterfly inlays, one on each side?
