quick tailight help
Anything electric, AC or DC
quick tailight help
Postby Aaron Coffee » Fri Sep 09, 2011 3:52 pm
Will be wiring my taillights tonight, (41 Chevy leds)the instructions say for the taillights say green to stop/turn and black to tail. Used a test power source and the black wire lights up the brighter lights, which should be the brake lights, correct? So do I wire it per the instructions or opposite so the bright lights are stop turn and the dimmer ones are tail?
Thanks
Aaron
If I could shut my brain off, I could save myself alot of time, money and effort.
Aaron Coffee
Images: 26
Postby dh » Fri Sep 09, 2011 9:21 pm
I'd make the brighter ones the stop/turn, like every other trailer light I've ever come accross.
dh
Postby Aaron Coffee » Fri Sep 09, 2011 11:39 pm
Thanks, thats what I did. Not sure if the instructions were wrong, the taillight wires reversed(didn't check but pretty sure they are made in China).
Aaron
Aaron Coffee
Images: 26
Postby Dale M. » Sat Sep 10, 2011 8:53 am
Is bulb in correctly...... usually these type of bulb have offset pins on shell so the only go in one way, but maybe nobody told the CHINESE prisoner making the product for 10 cents a day pay that.... OR maybe wires and (bulb) contact plate is installed wrong .... Throw instructions away and wire it so bright filament is stop/turn and dimmer filament is tail...
Dale
Dale M.
Images: 18
Postby Aaron Coffee » Sun Sep 11, 2011 12:56 am
Got wondering about the bulb, too. It's one of those leds that plugs into a standard socket. Isn't there also a double filament bulb that has the pins straight across rather than offset? I meant to pull a bulb and check it, but I was in a hurry as I was taking it to a car show today.
Aaron
Aaron Coffee
Images: 26
Postby 48Rob » Sun Sep 11, 2011 7:31 am
Aaron,
All the bulbs I've ever encountered that had the pins straight across were single filament.
Rob
48Rob
Postby Dale M. » Sun Sep 11, 2011 8:47 am
48Rob wrote:Aaron,
Rob
Correct.... And all the double firmament bulb have offset pins so the bulbs always go in with proper orientation as per function...
One would have to think that if colors of wires do not agree with written instructions as per function either the lamp assembly is wired incorrectly or whoever wrote instructions was/is color blind.
Dale
Dale M.
Images: 18
Postby Aaron Coffee » Mon Sep 12, 2011 11:15 pm
Got wondering if the led board was wired backwards, so I replaced it with a standard bulb and it worked the same, so apparently either the instructions were wrong or the pigtails were switched.
Aaron
Aaron Coffee
Images: 26
Return to Electrical Secrets
