eaglesdare wrote:did i misread? i thought the question was a build of 500lbs loaded including frame?
that is what my answer was to.
I apologize...I misread, thinking the 750 weight limit was the goal...
Oops...
Another example of "Sometimer's."
eaglesdare wrote:i will keep the things that i have used, and get rid of the rest.
Tiredoldwhiteman wrote:chartle wrote:
Whats your definition of small?
I was thinking along the lines of a full-size 12v gel cell battery...Heavier use, for sure...9 lbs is great...What are the amp-hrs rating? Of course, if all you're going to use is occasional LED lighting it hardly matters.
Regardless, at 9 pounds for the battery, that's a gain of an easy 50 lbs...
Good deal, f'shore!
Good deal, f'shore!
12 Ah I only would run maybe a light in the sleeping compartment and some lighting in the galley. No inverters running blenders for Margaritas.
Right now we only pull out our Coleman single mantle mini propane lantern if we are really cooking in the dark. Other wise we use small LED lanterns the size that would fit in your pocket. We are very much in the keep the light low and let your eyes adjust camp.
One thing I missed though a spare tire that's around 20 to 25 lbs if I want the bolt on carrier too.![]()
Oh and the jack and the stabilizing legs. I think I need a bigger boat er car.
GPW wrote:Why not toss the spare in the trunk (saving the weight of the bracket ) and stabilizers ? Just leave the TD hooked up ... No stabilizers ...
GPW wrote:Here’s one suggestion ... http://tnttt.com/album_ ... c_id=78197
