I am working my way through the construction posts and they have been INCREDIBLY informative. VERY incredibly informative! Kinda like a Tom Clancy novel!
So, can someone just point me in the right direction on a few key areas?
It's gotta be small, and light since I'm pulling it with a Yaris that Toyota says can't tow anything. I also want it pretty well insulated since I expect to do some cold weather camping. Heat will simply be a Coleman radiant heater. I hope to install a small AC unit too!
I have some aerotear plans coming but might just try to duplicate the Aussie teardrop design. Teardroptrailerparts has some cool looking aluminum siding with a little corrugation that I would like to use if I can. I found some aluminum insert moulding with a nice drip edge that should seal and protect the plywood edges (if I go that route) and harbor freight trailer is fine
I know alot of you like the wood look on both inside and outside but it's not for me. I will probably just carpet the interior 1/3 the way up and paint the ceiling a bright glossy white. And I REALLY like the look of a larger aftermarket door. And, if it makes sense, I wouldn't mind just getting cabinets from Ikea unless it's too heavy.
So ALL of this is what I have cobbled together from three days of reading.
But I still have some conceptual questions.
Walls: build up? 1/2" ply? 3/4" ply? Other stuff? Stability is crucial since I don't want leaks to develop but so is R-value. Ply would be easier but build up probably lighter. Thoughts? What are the implications for installing the door? I read that pine spars would be fine, right?
Should I skin the interior roof? If so, what with since it's going to be painted?
Finally, (for now) any hints for where the roof joins the walls?
Thanks in advance everyone!
