Deryk the Pirate wrote:Looks Sharp man! Cant wait to see some pics. So are you setting in a perm bunk bed in this 1?
deryk
terryjones1 wrote:Why the SPST switch in the cable connected to Shore Power?
Also, why the GFCI?
The rest of the AC connections look fine.
S. Heisley wrote:Zach, I like the idea of double fuse protection, provided you can get to all of them to replace them. That will protect the converter and trailer a lot better than just depending on the fuses in the WFCO.
You probably have the WFCO issue all figured out; but, just in case, please be certain to allow enough space around the back and sides of its compartment so that if it sparks from behind, it won't start a fire. Also, there is a cooling fan with a vented cover on the front. Covering those vents with anything, even a blanket, will negate your warranty and could even start a fire. If one of the WFCO fuses blow, the sparks fly out the front. (...Don't ask....)
Users browsing this forum: Bing [Bot] and 11 guests
