Ps. it’s been working/toasting for 4 years now ... so I think I got my 20s worth eh ?
Wolfscout wrote:You can put convection microwave in search at Amazon. They are pricey.
http://www.amazon.com/s/ref=nb_sb_noss?url=search-alias%3Daps&field-keywords=convection+microwave&x=0&y=0
This one has a 5 star rating:
http://www.amazon.com/Panasonic-NN-CD989S-Stainless-Convection-Technology/dp/B00412NL72/ref=sr_1_2?ie=UTF8&qid=1316857374&sr=8-2
GPW wrote:Just my 2 cents ... For our particular style of Camping (EVAC) , we’ve learned to keep it simple and easily replaceable ... For our trailer (s) I get the cheapest appliances at the biggest stores (Wal mart, etc. ), and due to their limited use , they last for years ... If they break , no big deal or expense ...
Don, can’t wait to see the pics !!!
CarlLaFong wrote:To match the curve, get a piece of cardboard the width of the finished cabinet. You can tape several pieces together if necessary. If it's not stiff enough, staple or tape a piece of wood to the back. It doesn't have to be pretty. Hold the cardboard in place, as high as it will go. Take a compass (the kind you draw circles with) and set it to the width of the gap at the center of the ceiling. A bit more won't hurt. Holding the point against the ceiling and keeping the compass as vertical as possible, draw a line on the cardboard. If a regular compass isn't wide enough, make one from a couple of sticks, a nut and bolt and a pencil taped to one stick. Sharpen the other one. If you have a steady hand and, maybe, someone to hole the template for you, you should have scribed a line that matches the profile of the ceiling. Cut along the line and test fit. You can make final adjustments and if there are any gaps, tape additional pieces of cardboard to it to fill them in. It might be ugly as sin when you are done with all of the tape and patches, but it's OK. Once the fit is to your standards, transfer the profile to your wood that you will be using. Carefully cut it out and, VOILA, there ya' go.
denmohr wrote:Don, I see your dilemma, how to match the "curve".......but, are you going to finish off the area between the wall and ceiling?
If so, that should be done first. Install that 1/4 round "cornice", for lack of a better word, run it a couple inches into the "cabinet space", past where the face frame of the cabinet will reside.
Once that is installed, take a piece of cardboard and place behind that 1/4 circle and scribe the curve. Done. When you make that face frame, make it 1/8" oversize on both sides..........it will snap in there and you have a perfect fit. OH,, when installing the "cornice, don't attach it to the structure (at least 18" from the proposed face frame location)...till the face frame is in, just in case you need to shim it out to make a nice clean fit.
Den
pete42 wrote:You could make the cabinet face frame from separate pieces of wood
looks sort of like an 8 on it's side.
