I bought this new from compact appliance thinking that a 12000btu would be overkill because I live in south GA and it gets hot so more is better,I may have got a bad one but from what I have read now after the fact that these do not work as well as they say they do.
It has a single hose and when I tried it the first time I had it under the sink and it was giving off some heat so I wraped the hose with insulation and that cut down on some of the heat,I then read that it needs to be 20 inches out into the room and that helped.
My trailer is grey in color and has 1 inch of insulation through out the entire trailer,the AC will get down to 60 degrees at night but by the middle of the day it's back into the 80's.
I have a honda 2000 and have read that the coleman cub will work with that size AC and is enough for a 7x16 and size trailer.
I don't want to have to buy a larger generator to run a larger like AC 1350 or 15000 btu?
