Simple LED conversion for low current.
Anything electric, AC or DC
Postby electronicx » Thu Oct 13, 2011 10:58 pm
Heres a simple way to lower the power used by your lights. Perfect for those of you running solar or for camping where you cant plug your trailer in.
I started with some inexpensive RV dome lights from ebay. Search for rv dome light.
With the 12 volt bulbs they come with, they draw 1.348 amps.
The bulbs are held in by a plastic clip and can be removed without any modifications or damage. I also bought a universal LED dome light conversion from ebay. There are a lot of different sizes shapes and configurations of LED dome light replacements for cars. They are very inexpensive. Search for led dome light. The one I bought had foam backed tape on the back. It fit perfectly onto the metal heat shield for the original bulb.
With the LED panel installed it only draws 0.215 amps or 215mA
I don't have any scientific way to measure the actual light output but it is plenty bright. I installed one on each side of my teardrop but only need to turn on one to light up the whole inside. They work so well I had to make one for the deer camp outhouse. It should run forever on a half dead 12v UPS battery from work.
electronicx
Images: 6
Postby Shadow Catcher » Fri Oct 14, 2011 4:56 am
Did that with MM #1 with cheep LED arrays from Hongkong.
Postby Snide61 » Fri Oct 14, 2011 2:45 pm
I saw similar LEDs at my local parts store. Do they have all of the resistors and all of that built in? If so that will help in my master plan to use an Edsel backup light housing as exterior lights wired w/ LEDs!!! YES!!!
Snide61
Postby tartosuc » Fri Oct 14, 2011 3:55 pm
best/cheapest place to buy LED light is dealextreme.com, lots of choices, just dont be in a rush to receive your order(usealy within 30 days but i've waited 2 months one time)
all the lighting in my trailer will be converted to LED
tartosuc
Postby bdosborn » Fri Oct 14, 2011 6:35 pm
I played with the LED arrays and like Cree emitters better:
Its way brighter with better color for the same current draw:
You can get them from Deal Extreme
Images: 806
Postby droid_ca » Fri Oct 14, 2011 7:37 pm
This is a really good thread
Thanks for sharing the step by steppictures are excelent
“Fide Canem”
viewtopic.php?f=5&t=52816
droid_ca
Images: 176
Postby bdosborn » Sat Oct 15, 2011 9:27 am
One thing to look for when buying LEDs is lamp color. Blue light (cool) from an LED bothers some folks, especially if they're older. Try and find a "warm white" LED. I like LEDs that have a color temperature around 4100K (a touch on the blue side) , but a little lower or higher still works for me. Everyone has a different perception of light so it might not be a bad idea to only buy one LED in a certain color to decide if you like it before buying more. Here's a link to an eBay seller that has the LED array in warm white for $5. Note the different connectors for about any RV light and the 100% feedback rating. A lot of guys at the big RV forum like this LED.
eBay Linky
Images: 806
Postby Nobody » Sat Oct 15, 2011 10:37 am
Thanks Bruce, for that link. I'm beginning interior 're-hab' of my 13' Scamp TTT & those lights just might work for me :thumbsup:
Harvey -
Nobody
Images: 342
Return to Electrical Secrets
