I have been reading alot of posts on electrical and my head is still swimming.
Ok. So I am going to be build a mini hopper style trailer as I just love the design for some reason. For electric I want to install a small 110 AC system for when I go to a camp ground. I want to simply just install a small breaker box with one 20 amp breaker feeding 2 outlets in the interior of my TTT. I will have the first outlet in the series of the two be a GFCI outlet so the second one is also protected. My question is do I or do I not ground the AC system to my trailer frame. I have read many posts but it still does not seem clear to me. I just am not sure if I am to run a ground out of the breaker box from the ground bar to the metal on my trailer frame so the system is grounded. Trailer body itself will just be plywood and then epoxyed and painted. Only metal would be screws and actual trailer frame. Any help with this would be really appreciated. If this is not the way to do this then I would like to know. I dont want to get cooked by touching the trailer or have anyone else get hurt either. Any help wold be appreciated. If you have any pictures of how you installed a system like this especially how you wired it in the breaker box and then how you ran your ground that would be awesome. Thanks fro the help.
