digitek718 wrote:Thanks for the replies..this forum is awesome.
- well I live in ny so we get both temperature extremes- hot and humid or bitter cold so good insulation is vital..How much cheaper do you think I would be able to handle an insulation job compared to the factory? is that a fair price? good call on the floor insulation..probably overkill.
I suggest not having the factory do the insulation, but you can remove the paneling and add the insulation once you get the trailer. Running wiring really sucks if there is insulation already in place.
- the 36x24 baggage door with lock is a fancy name for a cargo or access door that I had plans on sliding a cheap hd 5000 btu air conditioning unit in and out..guess i could just build a false wall on one side of the barn doors and mount the ac in there.
Are there size options other than 36x24? I would go as small as possible, but you always risk having something come up that makes it unable to fit.
- the 12 volt powered vent is just a regular vent prewired to a switch on the wall just in case I ever wanted to add a fantastic fan I wouldnt have to take apart the ceiling to run wires..especially if I get the roof insulation and liner..they do have an option for a fantastic fan but it sounds pricey-419 american..and a maxxair vent is 55
I would confirm if the cut-out and the wiring spec is the same size between the two, and if replacing the maxxair with the fantastic yourself would void the warranty or not.
-I wanted to do my own electric originally but I figured if I get the thing insulated it might be a pain taking the walls and ceiling apart to run wire..
The factory would never get the outlets exactly where you need them anyway (it'd suck to end up with an outlet halfway concealed behind a cabinet, etc), thus I'd say to do it all yourself even though it is more work. Running sheet insulation in walls is pretty easy and wiring is very simple to understand if you find a good how-to book.
Do you have a floor plan sketch of what you'd like it to look like when you're done? I'm still months away from buying a trailer but I've been leaning towards a 6x12' v-nose. My plans are a bit different than yours (I dont have a bike or ATV), a rear galley occupying the entire 6' width, queen bed on the floor with a double hammock above, hopefully able to store the hammock and flip the queen up for a small table in case of horrible weather, and with enough space for a slide-out toilet on the road wall opposite the entry door (some kind of privacy curtain would obviously be important
