Ultralight Design?
Postby bg » Mon Feb 27, 2006 7:18 pm
Mike,
I hade been looking for a design I could frame out in steel, couldn't find anything I liked, then a few days later you post this. :lol:
Revised weight Est is 325 lbs. Should pull very nicely behind my car.
I should also note that I plan on installing the floor in 3 pieces, after the main structure has been completed.
Bobby(, Kim & Wayne)
bg
Postby Miriam C. » Mon Feb 27, 2006 9:06 pm
:o :thumbsup: :thumbsup: :thumbsup: :thumbsup:
Lordy! That was fast!
Good Job
Enjoy
Miriam
Need to learn welding :thinking:
ultralight
Postby oklahomajewel » Mon Feb 27, 2006 9:07 pm
bg wrote:I'll only be picking up 260 lbs of steel in the morning. 'Course part of that is for Julie's trailer to fix my boo-boo :oops:, ......
Comments/critiques, please!
My trailer? boo boo???? whazzup, Bobby ?!
:shock:
oklahomajewel
Images: 82
Re: ultralight
Postby bg » Mon Feb 27, 2006 9:10 pm
:shock:
:lol: I just accidentally cut a piece of steel 4" short, no biggie.
bg
Postby mikeschn » Mon Feb 27, 2006 9:20 pm
I think we are at the end
Here's what the ultralight looks like...
and if you want to spin it around, here the wrl...
http://www.mikenchell.com/Ultralight/ul ... kinned.wrl
P.S. I am showing the optional 50* tongue in the wrl, which happens to be very similar to what C. Craven sent me this evening...
Postby GregB » Mon Feb 27, 2006 9:21 pm
Wow, that's a beautiful thang!
I'm not dead, yet. I'm feeling better.
GregB
Images: 108
Postby Miriam C. » Mon Feb 27, 2006 9:35 pm
:M :P :M :bowdown:
Looks good from here. :frustrated: :throw PC:
Puter too slow tonight. It's jellious
Get the spin tomorrow.
Miriam
:miriams: Thanks~
Postby bg » Mon Feb 27, 2006 10:08 pm
Mike: Am I straying too far from your original idea? I know doing the steel framing puts the project out of most peoples grasps.
Do you want me to continue updating in here or my own thread?
bg
Postby mikeschn » Mon Feb 27, 2006 10:13 pm
I think most of us here would like to see your steel version of the ultralight. So by all means, keep posting pictures... it give us a nice contrast to those of us who build in wood...
Postby bg » Mon Feb 27, 2006 10:18 pm
Alrighty then. Will keep updating.
Just FYI, I have 2 hours in the template/framing design, 3 hours for each side totaling 8 hours so far.
bg
Postby Micro469 » Mon Feb 27, 2006 11:24 pm
O.K. I know it's in here somewhere... How do you open a WRL? :roll:
John
Micro469
Images: 382
Postby bg » Mon Feb 27, 2006 11:28 pm
You need a program called 'Cortona'
http://www.parallelgraphics.com/products/cortona/
bg
Postby Feral XJ-SC » Tue Feb 28, 2006 1:14 am
angib wrote:I hope Mike will now add a post showing the alternative A-frame tongue that I sent him for the Ultralight, as his 3D lighting skills (or software!) are much better than mine. I believe this could be scaled up to a heavier trailer, using 2" square tube, rather than the 2" angle that is sufficient for the Ultralight. By using an A-frame, the back end of the tongue(s) can now lie right under the sidewall which is as solid a mount as you could want. However on the Ultralight this point is right at the front of the axle mount angles, so the length without a chassis drops to zero.
Andrew
I kept trying to figure out where the A frame was and I couldn't find it. Why the decision not to use the A frame? Was there a discussion off lthe forum?
Robert
Feral XJ-SC
Postby mikeschn » Tue Feb 28, 2006 7:47 am
Hey Robert,
There were three designs that we considered...
All three of these designs would work...
I chose the green tongue with the tabs welded on for it's simplicity.
The blue a frame tongue is nice because it actually touches the angle asm/spring bracket. You could run a bolt thru both, or even weld it up if you wanted. This is the alternative a frame design that Andrew was talking about...
I
But ultimately, I think I will go with this tongue arrangement. This is the alternative straight tongue that Andrew came up with. These are the tongue pieces that came with the HF 1175# trailer. We'll just have them welded together, weld a piece of tube on the top (shown in yellow) for the coupler to bolt to. Strong, light, and affordable! ;) Remember, we have matching plates on the other side of the floor, in the cabin, and the bolts go thru a 2x2 between the top and bottom sheets of floor plywood.
Postby mikeschn » Tue Feb 28, 2006 7:57 am
In each case, the tongue extends beyond the front profile of the teardrop by 22" as shown in this picture...
I believe Andrew worked it out and said the car can angle 45* before touching the trailer. Andrew, did you have a picture of that?
Return to Member Designs
