Floor Bolts
Floor Bolts
Postby ukuleleblues » Tue Oct 25, 2011 6:44 pm
A lot of the plans call for 5-6 3/8 inch carriage bolts per side for the floor. Man that seems like overkill. I was going to use 8 - 1/4 per side and 3 for each of the ends and 4 cross supports. That even sounds excessive. Any reason the for 3/8s that you all know of?
I was going to use stainless steel but wanted to ask if you all think galvanized painted would be OK, I’d loctite the nuts.
ukuleleblues
Postby grant whipp » Wed Oct 26, 2011 1:01 am
I've never used more than 4 per side (on an 8'-10' long body), and I use 5/16" x 2" elevator bolts instead of carriage bolts (e-bolts have a flat top, not the domed top of the c-bolts), thru 3/4" plywood floor. Loctite & lock-washers ... yeah, belt & suspenders ... :thumbsup: ...! IMHO ... stainless steel bolts & nuts are great if you plan on removing the body fairly often, but if not, then zinc-plated w/aforementioned loctite will work fine for many,many years.
Good luck, and ...
CHEERS!
Grant
(Funny ... spell check wanted to spell loctite as lactate ... :lol: :o :lol: :o ...!)
grant whipp
Teardrop Manufacturer
Images: 117
Postby KenC » Wed Oct 26, 2011 9:20 pm
I too used elevator bolts, five on each sides and two on each ends, mine is a 5 x 10 Benroy. I tried carraige bolts first but I could not get them to grab, they just kept spinning
KenC
Images: 41
Postby jdarkoregon » Wed Oct 26, 2011 9:55 pm
I took apart a tent trailer, there were ONLY four screws total holding the floor to the frame,
It don't take many
John
Innovation is essential
The world can be better
jdarkoregon
Images: 47
Postby Steve_Cox » Wed Oct 26, 2011 11:25 pm
I used self drilling/tapping trailer floor screws and they seem to work pretty good. I remember spacing them rather sparingly. No need to pre-drill holes in light gauge trailer frames and they are flush with the floor when screwed in. Here's a link Trailer Floor Screws
Steve_Cox
Images: 196
Postby jss06 » Thu Oct 27, 2011 7:24 am
I used 10 (5 per side) grade 8 1/2" bolts with the floor sandwiched between 2"x2"x1/4" steel plates. The bottom plate is welded flush to the top of the frame.
Overkill? yes.
Will the body ever come off the frame? Only during total destruction.
jss06
Palladium Donating Member
Postby Moho » Thu Oct 27, 2011 10:00 am
When disassembling the popup for my frame, Rockwood used galvanized sheet metal screws, roughly #10 or so, there were roughly 15 screws holding the plywood subfloor on and it was still on tight after 32 years.
Moho
Images: 69
Postby Larry C » Thu Oct 27, 2011 5:50 pm
grant whipp wrote:I've never used more than 4 per side (on an 8'-10' long body), and I use 5/16" x 2" elevator bolts instead of carriage bolts (e-bolts have a flat top, not the domed top of the c-bolts), thru 3/4" plywood floor. Loctite & lock-washers ... yeah, belt & suspenders ... :thumbsup: ...! IMHO ... stainless steel bolts & nuts are great if you plan on removing the body fairly often, but if not, then zinc-plated w/aforementioned loctite will work fine for many,many years.
Good luck, and ...
CHEERS!
Grant
I used to work for an industrial distributor, and I can't remember how many people I turned on to elevator bolts. Grant... thanks for a great suggestion. For this application, I doubt there is a better choice.
Larry C
"If its worth doing it's worth doing Light"
http://www.tnttt.com/viewtopic.php?f=50&t=35852
Larry C
Images: 78
