by mikeschn » Tue Feb 28, 2006 10:49 am
Depending on your skinning method will probably determine you you finish your door threshhold....
If your're painting, just paint the threshhold.
If you're covering in aluminum, just use aluminum angle
If you're covering in filon, use aluminum angle
If you're building a woody, just seal it with epoxy or spar urethane.
I wouldn't know how to use that seal you have pictured up there...
