in pulling my tear, it tracks great,, and the back end doesnt sway or move around but when looking in the side rear view I notice a bit of side to side movement,, almost a vibration movement,, its not over half to an inch but its still there about half the time,, it comes and goes fairly regular,, it will be there and then quit and then start back again,,, and this is only visible in the rear view, and not from behind the trailer,,
I have checked the alignment and the coupler to the outside of the axle is maybe a 16th difference,, tires measure aligned measureing from one tire to the other,, bolts are tight on the axle,,I have checked the obvious,,
I have a fairly long tongue and a light weight trailer(600lbs) give or take a little,, and close to 10% tongue weight,,,
Is this a problem and should I be concerned or is the pickle just excited to be on the road??
thanks in advance ,,
chipper
