Door, make it? Buy it?
Postby RIVERMOUTH » Thu Nov 03, 2011 11:02 am
Well I have been making a list of parts I need to purchase.
The question I have is... do I make a door or buy one?
One door or two?
How did you make your doors?
If you bought it . from where and what kind?
is there an advantage to either one?
I am building a 4x8 tear drop with aluminum skins.
where I live it rains alot!
RIVERMOUTH
Postby Forrest747 » Thu Nov 03, 2011 11:33 am
I am making mine. It all part of the "using Jeep Parts" on this build. WHat I have found is that mine are heavy and I am sure if I bought it would be much lighter, but then the look wouldnt be the same. Going to route out some of the wood to hopefully make them a little lighter. Let the sawdust fly.
Forrest747
Cowbell Donating Member
Images: 447
Postby oregonguy » Thu Nov 03, 2011 12:12 pm
The door is one of the big decisions isn't it....a tough one too. Custom shape doors are very attractive, but are difficult and, time consuming, and sometimes expensive to make. Prefab doors are also expensive, but save you a literal TON of time and effort.
Two doors is the way to go. I have had both, and will never do 1 door again.
There isn't a wrong choice, it all depends on how much time, energy and money you are willing and able to invest in this aspect of the trailer.
Good luck on your build whichever route you choose. :thumbsup:
Check out our Website: www.oregontrailer.net
oregonguy
Images: 48
Postby len19070 » Thu Nov 03, 2011 2:58 pm
It all depends on what you want to do?
After 20+ years of trial and error, I buy my Doors. (unless a customer wants otherwise.)
By the time you figure in all the expenses, $90-100 for a window, $35-40 for a GOOD lock, another $40-50 for moldings and the same for the rest of the materials, hinges, sealant, mistakes, blunders, hours of standing around scratching you head and the weekend or 2 it will take to do it, just to see if what you've done will work......Its a real coin toss.
I will say this, Manufactured doors won't leak, go in easy and the Lock always works.
http://www.ebay.com/itm/RV-Teardrop-Tea ... es&vxp=mtr
But if your looking for a Project, as some people are. Make them!
Happy Trails
Len
len19070
Images: 24
Postby RIVERMOUTH » Fri Nov 04, 2011 11:46 am
thanks for the input, after what you said len, I think I am going to buy a door. after What oregon guy said, I'm going to buy two. now that is going to change all of my plans. I'll see oregon guy in a few weeks. maybe I can get a trailer base built buy him.
thanks again
Rivermouth
RIVERMOUTH
Postby RIVERMOUTH » Sun Nov 06, 2011 11:24 pm
do you have a picture? was the door you found in good shape?
RIVERMOUTH
Postby Oldragbaggers » Sun Nov 06, 2011 11:36 pm
len19070 wrote:It all depends on what you want to do?
Happy Trails
Len
You're quite a salesman Len. I'm ready to place my order.
Becky :)
Life is sooooo good.........
Sail...camp....bike...repeat
Becky
Oldragbaggers
Images: 331
Postby urbanfixie » Tue Nov 08, 2011 2:06 pm
I just rec'd both my doors in the mail yesterday from Frank Bear (eBay). They are nicer then I expected and the install is going to be far simpler then I expected. I have never built a door but I am beyond happy with these and think the money was well worth how long it would have taken to make them. The other thing I love about them is the window opens up from the bottom allowing a breeze across your face when laying down. Hope this helps.
Check out "The Bug" at ourteardroptrailer.tumblr.com
urbanfixie
Postby Oldragbaggers » Tue Nov 08, 2011 8:58 pm
urbanfixie wrote:I just rec'd both my doors in the mail yesterday from Frank Bear (eBay). They are nicer then I expected and the install is going to be far simpler then I expected. I have never built a door but I am beyond happy with these and think the money was well worth how long it would have taken to make them. The other thing I love about them is the window opens up from the bottom allowing a breeze across your face when laying down. Hope this helps.
I'm ordering mine on Friday. I have purchased from Frank before and talked to him several times. Nice guy. We're stimulating the economy, right??
Becky
Oldragbaggers
Images: 331
Postby canned o minimum » Tue Nov 08, 2011 9:07 pm
I own a Little Guy and jus love the way the windows slide UP to open and ya have that fresh air right ON yer face !
If ever I build a door, it'll hafta have a LOW window, but this time I want it to open from the bottom with a hinge at the top of the window so I can open it even when it rains !
canned o minimum
Postby jabrobbins » Sat Nov 12, 2011 9:19 am
Two things I have discovered camping with the pre-made doors is:
Make sure you install them at the correct height for you mattress. The door edge is just rolled aluminum and can make exiting painful if your mattress is too low.
The doors shut tight and take a little technique to close. It may be that my weatherstripping needs to break in a little more. But, it is easy to sneak out in the middle and close the door from the outside, but once you return you really have to pull hard on the door from the inside to close it, which could wake up your partner.
jabrobbins
Eureka, CA
jabrobbins
Images: 35
