LWW wrote: I use West System Epoxy for everything I do in glass since discovering it 18 years ago. Simple mix ratio and easy to apply and yes it is expensive and yes it does work. Just my experience yours may be different. Larryw
LWW wrote:You get what you pay for. I've only used polyester resin once and I haven't used it since. I use West System Epoxy for everything I do in glass since discovering it 18 years ago. Simple mix ratio and easy to apply and yes it is expensive and yes it does work. Just my experience yours may be different. Larryw
Larry C wrote:I have previously kept silent on this subject not wanting to start fanning the flames, but when I see so many new members believing that a certain expensive product is a must for their build, I feel I should add my opinion. I know this will surely start the flames, but remember it's is just my opinion, and is worth exactly what you paid for it, your mileage may vary, etc.
When I came to this forum from boat building for 25 years, I was surprised by the CPES following on this forum. Over the years on many boat building forums, the subject of CPES has come up from time to time. It usually starts a lively discussion that ends in the consensus that it is just "Snake Oil" and regular epoxy is superior, and much less expensive. Just go to any boat building forum and search CPES or open a new discussion, and see what comes up.
I have used Wests, System Three, Raka, MAS, and others. These are just regular epoxies, and have all worked great, and for me have held up to years of use, as they have on thousands and thousands of boats for at least a half century.
Why would anyone building a teardrop trailer using new wood want to use a product that is by design intended for wood rot repair, especially when it's much more expensive than the right product to be using.
If CPES was actually as wonderful as the sales-pitch says it is why are there no major competitors? Through recorded business history, anything that has such a strong market share and price structure as CPES, also has competitors and imitators! Also why is this copyrighted and patented (?) miracle cure sold under so many names: Smith&Co CPES, MultiWoodPrime, Lingu, RotDoctor CPES, LiquidWood? Why not just CPES, worldwide?
Larry C
Hello. I'm Steve Smith. I'm the guy who invented Clear Penetrating Epoxy Sealer [also known as CPES], back in 1972. I've gathered up and organized quite a bit of information about it, since then.
I originally invented it as a solution to slightly deteriorated wood. It turned out it also was (I modestly assert) the World's Greatest Primer for paint or varnish on wood.
It is distributed by Smith & Co. under two names, CPES (above) and MultiWoodPrime. The MultiWoodPrime website http://www.multiwoodprime.com/ has information about its benefits on new or sound wood. There is information at the main company website http://www.smithandcompany.org/ about the product and its use in the restoration of wood. One of my distributors is The Rot Doctor, who serves the general public with Internet sales.
The underlying science of how it works is given at http://www.woodrestoration.com/. There you can see time-lapse photographs,pictures thru microscopes, mechanical tests and even an open standard for this kind of product.
The information at those websites should answer a lot of your questions. If it makes new ones, just ask.
Steve Smith
S. Heisley wrote:
Larry C, you seem to be unhappy with this discussion thread. From what I see, there is no reason to be such. We, here on the forum, have given Chabeau alternate sources for other epoxy products and have even stated that there are other products that will work well on plywood and wood.
You also seem confused, asking about various names, thinking that a certain product has many. For this, I quote below:Hello. I'm Steve Smith. I'm the guy who invented Clear Penetrating Epoxy Sealer [also known as CPES], back in 1972. I've gathered up and organized quite a bit of information about it, since then.
Steve Smith
The above quoted from:
http://tnttt.com/viewto ... teve+smith
I do hope this helps stop any possible confusion. Please take any further questions and comments related to the product in question to Mr. Smith, who happens to be a forum member.
Sharon,
Unhappy with the discussion thread, on the contrary, I am more than happy to HELP fellow members make wise decisions. I am just making my contribution to the same thread that you are. You refer to "We, here on the forum" (we=you) as if I am not a member. I feel I have as much
right to contribute as you have.
