Odd Question. How do you camp in a TD?
Postby chartle » Sat Nov 12, 2011 11:56 am
OK Do I have your attention?
Yes I know how to camp. Been camping probably since my age was measured in months.
But when we camp now we have a tent. OK its raining, my tent either has an overhang or an awning. So you can either leave your wet shoes/poncho outside or at least walk inside and have a "mud area" to change before you get to your sleeping bag.
With a TD, you open the door sit down and boom you are in bed. Muddy shoes and all.
I have seen some TD's with side awnings but mostly without. Also my profile on my yet to even have a place to build it TD is maybe 5'2 tall. So if I added some awnings it would OK for my wife but not for me. Also I don't want to deal with an Easy Up canopy.
So what do you do? :thinking:
chartle
Postby StandUpGuy » Sat Nov 12, 2011 11:58 am
Maybe you need to make something a little bigger.
StandUpGuy
Images: 52
Postby chartle » Sat Nov 12, 2011 12:06 pm
Not really wanting anything bigger.
Not a stand up kind of guy. :thumbsup: :D
chartle
Postby canned o minimum » Sat Nov 12, 2011 12:09 pm
Campin IS campin ! Unless ya wanna go with a 40ft diesel pusher with ALL the ammenities...
Muddy boots jus go in a plastic tub and git shoved UNDER the TD..keeps the creepy crawlers outta the boots too.
The great OUTDOORS is NOT fer everyone ! WE lose a bit of "creature comforts" fer the amazing outdoors !
A 40 ft RV is NOT camping !!
That is not to say that "I" am against a 40 ft RV.. they have their place and sum of them folks is wonderful !
Teardrop folks are a breed all to themselves ! The BEST folks on the planet !
canned o minimum
Postby chartle » Sat Nov 12, 2011 12:18 pm
canned o minimum wrote:Campin IS campin ! Unless ya wanna go with a 40ft diesel pusher with ALL the ammenities...
Yea I get it, I just don't want to hear it from my wife that she is sleeping in a wet bed and why did you build this thing. :thumbsup:
This is more of a How To kind of question.
chartle
Postby jerry101jlh » Sat Nov 12, 2011 1:45 pm
Paha Que offers 10X10 screen room with over 7' ceiling height for Light Guy tears that very easily could be adapted to most designs as they use a suction cup type of affair to fasten to the side of the tear. Very weather proof as we have experienced rain with ours and dry is the name of the game
jerry101jlh
Postby Galen » Sat Nov 12, 2011 2:15 pm
I had the same questions and little issues when considering a tear drop. Then I figured, I am building it, so why not design it to fit my desires. So my design has a little bit more space inside, so you can sit, get dressed, have a small table, and a porta potty, and enter and exit without getting the bed dirty or wet. By having a drop floor and a raised bed I also get some nice storage underneath the bed. Overall length is a bit longer, but I am building it very light so I expect it will weight the same or less than most of the teardrops, and will still be a very small trailer that my subaru outback can tow.
Not that I am knocking anyone else's design or teardrops. I love them all.
Galen
Postby BillZ » Sat Nov 12, 2011 2:33 pm
I know you said you don't want to deal with an easy up but that is how I see most others create a shelter outside the tear. On the few Teardrop outings my wife and I have attended, nearly every teardrop has an accompanying tent shelter. Ours is a 12x12 and that is big enough to shelter the galley and have an overhang over both doors. We normally put our shoes under the tear or if the weather isn't bad, on the fender.
BillZ
Postby DMcCam » Sat Nov 12, 2011 2:37 pm
Hi Chartle, In designing our TD I had similar concerns. After reading a ton of threads a few practical ideas surfaced. We're going to have a couple of heavy duty umbrellas that I'll make exterior brackets for. They will cover the door areas giving us a chance to shake off before entering. We'll close them up after getting inside if it looks like heavy wind. Wet clothes, coats or windbreakers will hang inside on hooks aft of the doors. Our top bed cover will be water resistant. We plan on using cut to size rubber door mats made from commercial kitchens. Our local surplus store sells the stuff by the foot. It has pretty big holes in it to drain away water.
We usually change out of hiking boots at days end to slip-on footwear. If it's a heavy rain we might end up doing the 'under the TD bin thing. If light rain our TD has a shoe bin in the design so the wet slip-ons can be stowed inside in a pouch.
We will have an easy-up to give us more cover if it's a prolonged drizzle.
Cheers,
Dave
DMcCam
Postby Gaelen » Sat Nov 12, 2011 3:14 pm
With my Sunspot, which is only about 6 inches "taller" than a teardrop inside, I used a tilting patio umbrella that provided alcove-style cover by the side door, and a Tailgator awning over the back galley (but it could have just as easily sheltered the side door.)
The Tailgator fits over the lift gate of my Jeep Patriot, as well as over the galley hood of my new-to-me teardrop. I haven't attached it on the side of the tear, yet, but I'm sure it will fit. The nice thing is that you can adjust the angle of the ceiling - so even someone 6 ft. tall can exit the teardrop standing up. And putting it up is a five-minute, one-person job. It's also only 7 or 8 lbs - way easier to manage and haul than even an inexpensive ez-up style canopy.
Other choices for side and rear cover include things like Kelty's Carport. I have the medium version, which is smaller and more suited to working off a door. It didn't attach well to my Sunspot due to that door's sharp edges, but it will work very well off the side door of my teardrop.
I plan to have either a milk crate (drainable) or a plastic bin into which I can drop wet footwear. And if it's drippin wet, I hang wet outerwear under the umbrella/door awning overnight. I always have at least two raincoats - one heavier, one lighter-duty - and alternate the dry one inside and wet one outside so I can minimize the amount of wet stuff I bring into the camper. BTW - that works just as well for 40' RVs as it does for teardrops.
Hope that helps.
Gaelen
Gaelen
Images: 38
Postby Wolfscout » Sat Nov 12, 2011 5:05 pm
When I tent camped.. I never brought in wet muddy boots into my tent. Why now that I have what I think is a very nice camper would I mud-muck it up now? I always kept a small tote with lid near the door of the tent. What I traveled with in it was some kitchen gear. When I was onsite it became my shoe box at the tent. I use it only for shoes and wet stuff at the camper door now. It's really nothing to worry about. shrugs.
Why you all wet and muddy anyways ? mud bogging? :thinking:
Larry Fulmer, Jr.
CTC 2
Wolfscout
Images: 32
Postby Gage » Sat Nov 12, 2011 6:01 pm
This is what works for us. Very simple. 10 yards of matl, two poles, a pair of tie downs and a hand full of snaps.
Image Image Image
Gage
Images: 28
Postby kirkman » Sat Nov 12, 2011 6:22 pm
Here is one of mine
kirkman
Images: 55
Postby kirkman » Sat Nov 12, 2011 6:26 pm
kirkman
Images: 55
Postby bdosborn » Sat Nov 12, 2011 6:38 pm
Images: 806
