EZ wrote::x
So I made this nice foam-core door out of 1 Xs and luan. Got myself a SS piano hinge, hung her up and it is warped. I was so sure that it was square and straight but it is warped from corner to corner.
So, first of all, how the heck do you make a nice door? Maybe the side of my camper is warped. I guess I had better find out.
And I was really hoping to be one of you guys who writes "I was afraid of making the door(s) but it turned out to be easy". Not this time. Hours down the drain.
Ed
Ed...
I've learned that the only way to learn, is to do every thing wrong...
Why do I get the feeling you are learning too!
Okay, so your door is not flat... do you have a picture that would show us what's not flat... Don't shake your head, I'm serious here...
The last door I built was not flat, so I cut a strip off, and glued on a piece of oak that was warped in the other direction. The end result, was a flat door. Granted, I painted that door... if that's an option for you... let us know...
If you're doing an aluminum door, bolt a piece of structural aluminum to it...
But I'll wait for the pictures before I make any more suggestions...
