by Engineer Guy » Wed Nov 23, 2011 1:05 am
I've got 2 Atwood Furnaces. The '89 one is a 12k BTU pretty identical in Form Factor to the one pictured. I've worked pretty extensively on the older '83 one; a 16k BTU or so. I don't have the Schematic here, but know it like the proverbial back of my Hand.
I don't believe you have any problem, nor need to make further Mods. Rigorous testing will tell...
There's 2 'Snap' Mechanical Sensors on mine; each the size of a Quarter with 2 mounting Screw Holes on them. My Reverse Engineering, to understand the functions, concluded this... One Snap Sensor is Normally Closed. So, the Furnace comes on and runs until the Temp Setpoint is reached/exceeded. So long as the Thermostat is calling for Heat, this Sensor opens, interrupting Control Voltage to the Gas Valve, which discontinues the Heating. The Fan runs, and cools down the Plenum. This Sensor closes again, and Gas/Ignitor Spark comes back on, exactly as you describe. This continues until the Thermostat no longer calls for Heat. However, the Fan continues to run; the major difference between this Sensor function and the next one I describe.
The other, similar-looking Sensor is the 'Fail Safe' Sensor. If all else fails, or some weird, unforeseen situation arises, this Sensor heats up; opens; and ensures the Furnace operation ceases so as to not burn down the Trailer. The Fan stops, etc.. You can hear the Plenum Metal 'ticking' as it cools off, since there's no Fan to force cool it. But, Mission Accomplished. Fire avoided. It has a higher internal Setpoint cutoff temp than the other Sensor.
I removed these 2 Sensors during Troubleshooting and attached my Ohmmeter. I heated each one with a Match to see how they were supposed to operate. I replaced a bad one after a local RV Shop 'Gomer' wanted to argue with me that I didn't know what I was doing. Turns out I did. I voted with my Feet [and Wallet] and no longer patronize that Shop.
This sort of simple, Mechanical Control is cheap, and works. These Replacement Sensors are $7- or so. Whether a Sensor is N.O. or N.C. is represented differently on any Schematic. You can hear them 'click' and operate, like a little 'Frog Clicker' Toy of Olden Days.
Trailer Thermostats need to not have a Mercury-type Switch in them. Those old Models are sensitive to level, and suitable only for fixed Installations. The nice thing about using a Clip Lead to short together the Thermostat Wires is that it takes any Thermostat out of the equation and tells you how the Furnace ought to work.
If there's some Air Output/Air Distribution problem, then the confined Furnace won't raise the heated volume temp way up as it should. Confinement would cause 'premature' heating and opening of the cycling Temp Control Sensor. Barring that scenario, things sound OK. As an aside, our ~80% efficient House Furnace, circa '86, operates identically to the Atwoods. Heat up; run the Fan; cool down. Repeat as necessary...
Conventional Wisdom is to use only a Thermostat where an internal Battery powers the Electronics, including Programming Setpoints memory. The Furnace Leads do not [and should not] supply power in that scenario. Last time I checked, Wally World had one such Thermostat, and Home Despot had one or two... Both my 'Stats are Old School Mechanical types.
I'm a big fan of Ye Olde Scientific Method. When the Environment is the Variable under question, change it/make it irrelevant. Remove the Furnace - IF it's not a huge hassle - and run it in Free Air. I did this for my Troubleshooting. You'll hear/see the Sensor click on/off, and cycle the Gas Valve as 'normal' operation in an unconfined Environment. I short the Thermostat Wires together; power the Furnace off an ancient +12 VDC Battery Charger; and supply the correct pressure from a 20 lb Propane Tank plumbed in safely and temporarily outside [to ensure heavier-than-Air Propane dissipation]. This sort of Test Config takes less time to set up, actually, than cutting out new Vents, etc., on speculation. For my Brain, establishing the 'baseline' of proper Furnace operation is huge! You then know what not to question, and chasing one's Tail is minimized. As is the case with my '89 Atwood, I would cover up any 'extra' Venting temporarily to force all warm Air out the Front Panel. This would ensure Plenum cooling by Fan in a known manner, and would help establish Furnace operation baseline.
Disclaimer: I Speed Read this Thread, and might have missed something...
P.S. - Thermostats are designated '24 Volt' because that's the standard House Furnace AC Control Voltage. They're 'dry' Contacts, as noted above, and can also handle +12 VDC in a Trailer. In the Olden Days, the round Honeywells had a small, visible Mercury Switch in them. Today, most all 'Stats are 'dry' Bimetallic Spring-driven Switches.
The other primary Home Thermostat convention is called 'Line Voltage'. It can typically handle either the 115 or 230 VAC used to directly control Electric Baseboard Heaters.
~Reality proceeds with or without your consensus~
