RV Style Windows?
RV Style Windows?
Postby dabber » Wed Nov 23, 2011 11:00 am
Looking for a couple sources for rv style windows? Going to put a couple in my 6x10 and had no clue where to order or look.
Thanks
dabber
Postby BC Cargo » Wed Nov 23, 2011 1:35 pm
I would do an internet search of manufactures in your area and see if they will sell to you direct. This what I did and they made custom windows for me in the frame colour I wanted with the glass they had in stock...which was the cheapest "new" way to go other than used windows in your local Buy & Sell blog or paper.
http://tnttt.com/album_ ... c_id=85133
BC Cargo
Images: 87
Windows
Postby drcurran » Wed Nov 23, 2011 3:51 pm
http://www.rvdoctorgeorge.com/
Might give Dr. George a try. Good luck
Dan
"I'm not as good as I once was, but I'm as good once as I ever was."
TK
drcurran
Images: 20
Postby chartle » Wed Nov 23, 2011 4:19 pm
Also look up shed windows. Much cheaper.
chartle
I used these
Postby Blotto Bros » Wed Nov 23, 2011 7:00 pm
I highly recommend this vendor. I have also had good luck with going to a TRUCK salvage yard....the windows from sleeper cabs are almost identical!!
http://www.teardroptrailerparts.com/Windows___Doors.php
Even those souls that are found must occasionally become lost to appreciate what they have.
Blotto Bros
Images: 51
Postby John T. Hodgen » Fri Nov 25, 2011 9:44 am
Hey Dabber,
I found my homebuilt's at lowes, but go to an RV seller that also sells parts. There is one on Hwy 19 towards Beckley who has a big supply of parts. Also in Summersville on hwy 41 towards Craigsville. I could go by and see what they have for you. 6x10,right? How thick do you need, You probable could trim the thickness to the size you need.
Til later by the fire--John T. & Linda 8)
John T. Hodgen
windows and other parts
Postby seabee74 » Thu Dec 08, 2011 7:41 am
go to Teardroptrailerparts.com and find most anything you need
seabee74
Images: 7
