Bubbles in my spar finish...any ideas?
Postby Larry C » Thu Nov 24, 2011 11:42 am
driftwood wrote:makes me ill to think about having to sand all the way down the base wood and start over again. My wife wiped the wood with a wet cloth and it looked fine, could dnot really see where I sanded unevenly. She thought that was an indicator of how it would look when recoated with spar coats, and that it would be ok to add more coats now. Anyone have any thoughts on that?
Guess I could just test and area, let it dry, and see....
Pictures might help.......
"If its worth doing it's worth doing Light"
http://www.tnttt.com/viewtopic.php?f=50&t=35852
Larry C
Images: 78
Postby Miriam C. » Fri Nov 25, 2011 5:55 pm
:thumbsup: If you are not a professional wood finisher you are not likely to get a perfect stain nor a perfect finish. And if anyone ever mentions it just tell them only God is perfect...MO
I live in Joplin MO and really struggled to get a day with less than 50% humidity...I just waited but you can get a dehumidifier and should get a dryer finish. As for dust :? You can always vacuum walls......NOT---Trick is to do your best and enjoy the process... ;)
Postby driftwood » Tue Nov 29, 2011 11:04 pm
ok, took some advice from everyone and strained the spar thru cheesecloth, replaced the brush, and applied new coat in more dust-free environ and worked much better! One more coat and I will call it a day. Not perfect, but acceptable for sure. Thanks for the input!
driftwood
Images: 28
Postby 48Rob » Wed Nov 30, 2011 8:23 am
Congratulations on your success!
Please post pictures of your project, varnished wood is just so pretty to look at! :thumbsup:
Rob
48Rob
Postby driftwood » Wed Dec 07, 2011 8:30 pm
Ok Rob, here are some pics of he finished tables. They fold in the middle for easy storage in galley. Built one for other side of galley as well. Thanks for the help everyone.
driftwood
Images: 28
Postby bobhenry » Thu Dec 08, 2011 7:42 am
Postby 48Rob » Thu Dec 08, 2011 8:04 am
Your tables look very nice.
They're sure to get a lot of use, and plenty of nice comments too.
Good job! :thumbsup:
Rob
48Rob
