Realistic Cost
Postby absolutsnwbrdr » Thu Dec 01, 2011 4:11 pm
Vedette wrote:Most of the time it is cheaper to buy one than to build one.
I don't necessarily agree with that. If you're talking buying a used teardrop vs. building a new, then yes. But buying new vs. building new, then no.
Zach
Coming Soon...
absolutsnwbrdr
Images: 412
Postby gregp136 » Thu Dec 01, 2011 4:46 pm
I most likely could not get the money and time I put into it if I sold it, but no, I could not have gotten anything decent for the money I spent.
Greg(and Laurie)
gregp136
Images: 100
Postby 48Rob » Thu Dec 01, 2011 7:00 pm
I have seen a few come up for sale, pretty nice ones too, that I could have bought cheaper than I will spend building. But when I look at them I don't see "me". And the building is a blast.
Yes! :thumbsup: :thumbsup:
Sometimes it is the journey!
Rob
48Rob
$4500+ for The Shack
Postby Jim Edgerly » Fri Dec 02, 2011 1:25 pm
I kept very detailed records up until near the very end, and I spent over $4500 on mine. $4500 was close enough for me...I don't need to know how much over that I went.
Trailer $600
Welding modifications $200
3500 lb axle with electric brakes $283
14" radial tires with rims $236
6 sheets marine grade plywood $300
aluminum for roof $325
8" queen size RV memory foam mattress $230
epoxy $180
2 gallons spar varnish $80
battery $120
battery charger/converter $115
door/galley hinges $120
door/galley latches $92
windows $140
clear pine trim $150+
These "big ticket items" come to around $3200, then I got nickle-dimed to death on the rest...9-10 items in the $50-$80 range, 20 or so items in the $20-$40 range, and more items than I care to count in the $10-$20 range.
I bought "what I wanted" and pretty much ignored the cost. As "mikeschn" has at the bottom of every one of his posts..."The quality is remembered long after the price is forgotten, so build your teardrop with the best materials..."
*When doing anything, if there exists no possibility of failure, then any feeling of success is diminished.
**The glass is neither half full nor half empty...it is simply twice as big as it needs to be.
***If at first you don't succeed, redefine success.
****When I die, I want to die like my grandfather, who died peacefully in his sleep. Not screaming like all the passengers in his car.
Jim Edgerly
Images: 142
Postby Big Dan » Fri Dec 02, 2011 4:03 pm
I bought mine new $3,500 Image Its not big but its big enough.
"Happiness is only real when shared" Alexander Supertramp
Big Dan
