So I just cleaned out a box of old sample crap from my work that has been under my desk for years and in there I found a few LED light fixtures from HERA. There is 1 puck light (3 LED), 2 long flexible stick lights, and 1 shorter rigid stick light. HERA makes great lights and their quality is very high! So I'm hoping I can use these in the trailer.
I have 2 transformers with them also. Now I'm guessing that the transformer is to convert the 100-120 AC current down to 12V DC current? On the pigtail of the transformers where the lights plug into it says 6-24VDC max. 3A. Now I'm assuming this means you can plug anything DC that has a voltage of 6-24 volts, correct? I've looked all over the lights and no voltage rating. Only 0.35A current and 1Wx3 LED. And HERA's website doesn't have this info listed... That I could see anyway.
Does anyone know if I could wire these lights directly to my 12v system and use them in my benroy? Of course they would be wired through the fuse block. What size fuse to use? And could I run them all on the same circuit?
Robbie
*Here is a link to the puck light fixture...
http://www.lbutampa.com/Lighting-Fixtur ... -0LFS0-WW/
