by Jim Edgerly » Tue Dec 06, 2011 3:52 pm
I have been rebuilding my doors on The Schnoodle Shack as those familiar with my build journal already know. I fitted them to The Shack, stained them, and was now ready to start the finish process. I used Raka epoxy resin on The Shack back in September, and I am very pleased with the results. Easy to work with, nice finish. Well, I placed my doors in a convenient to work location in my workshop, pumped 3 ounces of part A (resin) and 3 ounces of part B (hardener) into my container and started mixing, for 2 minutes as recommended in the manual. Those familiar with Raka already know the problem. The temps in my basement are a bit cooler than outside in Sept, so the consistency is closer to a "nectar" than the varnish consistency it was in the warmer temps, but no problem, I can still spread it OK. So I completely finish the first door, and I go to mix more for the second door...and the realization of what I had done hits me in the gut like a sledgehammer. I see how much lower the resin is in jug A than the hardener is in jug B...because you use TWICE as much resin than you do hardener for a proper mixture! I had carelessly mixed it 1:1 instead of 2:1. I immediately ran upstairs and called the Raka sales line.
I talked to Larry, who answered on the 3rd ring. I asked him if I had just ruined my project, and he didn't answer with a yes or no. What he did tell me was that the epoxy resin as mixed would never totally harden, and that it would always remain "rubbery". He asked how long since I put it on and when I told him just a few minutes since I finished he told me my best bet was to go down and scrape off as much as I could as fast and I could, and wipe down the door with acetone or varnish thinner afterwards, and sand off what I could not remove.
60 seconds later I had grabbed a handful of rags, an assortment of plastic putty knives, and was pulling on my disposable vinyl gloves. I thanked God for the cooler basement temp because the epoxy resin was still the consistency of nectar and had not even begun to cure, and the scraping process was not too bad. I placed a large piece of cardboard under the window "hole" where the window will go, and started scraping all the resin into the hole onto the cardboard (the door was already lifted off the table on blocks). Once I had as much scraped off as possible, I started the varnish thinner wash. I took an empty plastic margarine tub, put an inch deep of varnish thinner, and used half of a steel wool pad. I soaked the pad, wiped it over the door, then kept rinsing it out in the thinner and re-wiping the door. I changed the thinner a couple of times so as not to reapply a thin coat of resin, and after about 15 minutes of cleaning the door it appeared pretty clean. I then soaked a couple rags and wiped down the doors to get any remaining residue off. Luckily the thinner evaporates pretty fast, and after a couple of hours I recoated the door with the properly mixed epoxy resin. The door appears to be fine, but I swear my heart skipped a few beats once I realized what I had done.
I learned the soaking steel wool pad in thinner/varnish remover years ago from refinishing a table. I'm glad I remember it under pressure, and I hope someone else in here can use it in an emergency, that's why I'm posting this under General Discussion instead of just my build journal.
*When doing anything, if there exists no possibility of failure, then any feeling of success is diminished.
**The glass is neither half full nor half empty...it is simply twice as big as it needs to be.
***If at first you don't succeed, redefine success.
****When I die, I want to die like my grandfather, who died peacefully in his sleep. Not screaming like all the passengers in his car.
