Diamond Plate Wallpaper
Postby cargobob » Tue Dec 06, 2011 2:51 pm
cargobob
Images: 20
Postby snal » Tue Dec 06, 2011 3:56 pm
Wow!...$2.29 per square foot on sale! :(
snal
Postby BC_Explorer » Tue Dec 06, 2011 5:31 pm
I like the looks of the wallpaper however I am not sure that a CT conversion (or even a TT) is the place for wallpaper. I would think that the continuous temperature cycles between high summer and the cold/freezing/dampness in the winter would cause the paper to peel prematurely?
BC_Explorer
Images: 19
Postby OverTheTopCargoTrailer » Tue Dec 06, 2011 6:36 pm
Hi BC_explorer
Don't forget 4 yard min.... so $85 to start
I will let you know how well wall paper works after I get mine installed, you might have a good point, :cry: :cry: here is my wall paper selection.
http://overthetopcargotrailer.blogspot.com/2011/07/parts-are-finally-arriving.html
Praying that your wrong :worship: :worship:
Postby lonerider » Wed Dec 07, 2011 7:29 pm
:shock: :?
lonerider
Postby vreihen » Wed Dec 07, 2011 7:49 pm
snal wrote:Wow!...$2.29 per square foot on sale! :(
How much is the real thing per square foot????? :thinking:
vreihen
Postby roadinspector » Wed Dec 07, 2011 10:42 pm
0.024 cosmetic goes for about $3.00/sq/ft.
Dadgum it! I cut that board 5 times and it's still too short!
2001 quad-cab Dodge Cummins 3/4 ton camper special, 16x7x7 CT work in progress toyhauler, 01 HD Ultra Classic, 98 HD Heritage Softail, 88 HD 1200 Sportster. viewtopic.php?f=42&t=51510
roadinspector
Images: 127
Postby BC Cargo » Wed Dec 07, 2011 10:56 pm
After I put the walls back up, I filled all the holes and then primed the raw wood. Then applied diamond plate wall paper made by Martha Stewart and available in Canada at Canadian Tire for $22 a roll. Because I used diaomd plate PVC flooring 16 inches up the wall, I only needed one roll. This wall paper is thick and paintable as I did to seal the seams.
My Album has many pics of this...I have not done the trim yet.
http://tnttt.com/album_ ... c_id=85100
BC Cargo
Images: 87
Postby BC_Explorer » Thu Dec 08, 2011 5:09 pm
BC Cargo wrote:After I put the walls back up, I filled all the holes and then primed the raw wood. Then applied diamond plate wall paper made by Martha Stewart and available in Canada at Canadian Tire for $22 a roll.
I like the look of that wallpaper. Is it vinyl or paper based surface?
BC_Explorer
Images: 19
Postby BC Cargo » Thu Dec 08, 2011 11:23 pm
Paper and takes paint well in any color. It also hides a lot and can span small holes with no problem. However you have to treat your walls as you would the inside of your house...
BC Cargo
Images: 87
Postby snal » Wed Dec 14, 2011 6:25 pm
I sell the .063 aluminum tread-brite for $4.75 sq. ft....cost is around $3.50.
snal
