Here is the fuel tank.
Here is the plaque on the bottom shelf.
Not a Coleman but very interesting. Cannot find any info on this stove on the net.
Mark
Mark72 wrote:Ratkity, I guess it weighs in around 60-70 lbs. but I haven't picked the whole thing up. Had to disassemble it to get it stuffed in the car for the trip home.
Doug, It is a gravity fed fuel system. That is why the reservoir is mounted so high. Not to mention it is not air tight.The wooden knobs you see in the tubes on the sides of the fuel reservoir are pre-heater wicks for the vaporizers. You pull them out and light one for the burner you will be using and stick it in the flared tube you see in the second pic.
Mark
Mark72 wrote:Doug, It is a gravity fed fuel system. That is why the reservoir is mounted so high. Not to mention it is not air tight.The wooden knobs you see in the tubes on the sides of the fuel reservoir are pre-heater wicks for the vaporizers. You pull them out and light one for the burner you will be using and stick it in the flared tube you see in the second pic.
Mark
