if you are brushing on unthinned varnish, 3 coats is more than plenty.. biggest mistake people make is thinking more is better.. more is what causes finishes like varnish to craze.. long oil varnish is supposed to be a supple finish so it can move with the wood.. if you put too thick a coating on it will be rigid and crack..PSBreen wrote:A lot of our concern is about leakage around the roof/side joint. One of our thoughts is to use 2" fiberglass along that seam and then 4-5 coats of spar varnish over the entire trailer. Any thoughts?
starleen2 wrote:If you do use the 2' around the edges - go with the firberglass tape pre cut - it comes with a selvage edge that keeps it for coming unraveled.A real time saver. I've Cut 3 Inch strips before out of cloth and it was PITA to work with. Never again.
Juneaudave wrote: I typically stay away from tight weaves due to wet out problems....
