Yes Arne, I am going to try to build an ultralight...
I say that because we all know, some days are good, and some days are bad... today was a bad day.
Let me share a few pictures with you...
After I glued up those 1x4's I cut the template out of the 5.2mm luan... that's less than 1/4". Let me tell you... that luan is like a rubber band... it moves all over the place.... I figure, no problem, I'll clamp it down... Later on I find out that the 1 1/2" width isn't really enough to keep the router stable... but I'm getting ahead of myself... I set the template on top of the pine frame, and figured I'd make a practice cut...
The inside cut went fine...
then I tried an outside cut.... suddenly I noticed that the bit was cutting into the pattern....
Hey, that's not supposed to happen... So I look at the collar on the router... it either melted, or got chipped away... Needless to say I am not a happy camper...
I either need a better router guide, or I have to change my method of construction to the one that Subtear is using...
http://www.teardrops.us/userfiles/33/te ... anean.html
Hmmmm
![pipe :pipe:](./images/smilies/pipe.gif)
I think it's time to bounce this off one of our experts... Steve Frederick... Steve, your thoughts...
