Small corded saw
Small corded saw
Postby Ashleymeadow » Fri Dec 16, 2011 12:59 am
I have both a 7" and a 5" saw, but both are too big and clumsy when working on my TD. I saw the ad for the Rochwell Versisaw that made me think that I am not cutting anything over a half inch except the notches for the roof joists. I am just now cutting out the lower floor, and a small light-weight saw would be ideal for the rear of the wood work.
Anyone had any experience with small saws?
Jerry
"If we falter and lose our freedoms, it will be because we destroyed ourselves."
Abraham Lincoln
Ashleymeadow
Re: Small corded saw
Postby eamarquardt » Fri Dec 16, 2011 2:18 am
Ashleymeadow wrote:I have both a 7" and a 5" saw, but both are too big and clumsy when working on my TD. I saw the ad for the Rochwell Versisaw that made me think that I am not cutting anything over a half inch except the notches for the roof joists. I am just now cutting out the lower floor, and a small light-weight saw would be ideal for the rear of the wood work.
Jerry
Good question.
Cheers,
Gus
eamarquardt
Images: 150
Postby Treeview » Fri Dec 16, 2011 9:17 am
I follow a woodworking forum and the gang there is very helpful and knowledgeable.
Woodcentral
Corded for sure??? I wouldn't be without my DeWalt 18v tools even if I do have to replace batteries. Dragging a cord around is a hassle.
Treeview
Images: 30
Postby asianflava » Fri Dec 16, 2011 1:14 pm
One thing I've found is that the bigger the blade, the straighter the cut. I still don't trust myself, I clamp a straight edge for the saw to ride on.
asianflava
Postby Ashleymeadow » Sat Dec 17, 2011 3:33 am
I have been moving back to corded tool. Too often I start something just as the battery goes dead. I also thought that a saw might require more power. I think that I will get then Rockwell Versa saw, but I was hoping that some of you had experience with the small saw.
Abraham Lincoln
Ashleymeadow
Postby aggie79 » Sat Dec 17, 2011 8:38 am
The Rockwell saw is a very interesting tool. Please let us know how it works for you.
I understand your issue about batteries running out of power. I have a Ryobi cordless and it doesn't take long to drain the batteries. I do like its small size, handling, and no cord, but if I'm going to do a lot of cutting I'll grab my old corded Skil saw.
Take care,
Nice little saw!
Postby Ashleymeadow » Sat Dec 31, 2011 1:07 pm
I bought the Rockwell Versacut saw. So far, I find it works well for applications on the TD. The carbide blade is very thin making very little sawdust and leaving a narrow kerf. I like it lot! The vacuum attachment works well, but dragging the vacuum hose defeats the function of a small one-handed saw. The laser guide is really functional.
Downside is the plunge cut in plywood works okay, but I do not have a hand saw that is as narrow as the saw blade. Can't chisel plywood very well, so I find that I have to use the box cutter to finish the cutout. Nice straight cut though.
Jerry
Abraham Lincoln
Ashleymeadow
Postby aggie79 » Wed Jan 04, 2012 9:55 am
Thanks for the update!
Postby Kermit » Sat Jan 21, 2012 12:32 pm
For a small corded circular saw, there is none finer than this Porter Cable:
http://www.amazon.com/Porter-Cable-314- ... B0000222WY
The list price will give you heart palpitations, but the street prices are a lot less intimidating. Amazon's can be beat, but not by much. I have one of these and it's amazing. Set for a shallow cut, it will cut gentle curves. If you buy one, you'll have to put it in your will, or your progeny will fight over it. It's that tough--and useful.
Kermit
