slowcowboy wrote:even if it just boils water like they said. it would be a aset to me.
but I bet it takes longer than 10 minutes in wyoming at my alutde above sea leval!
eamarquardt wrote:slowcowboy wrote:even if it just boils water like they said. it would be a aset to me.
I don't think that a wood fire would burn any cooler at 6000 feet than at sea level unless there was a real restriction in the airflow. Water boils at 201f at 6000 feet versus 212f at sea level so I think it's reasonable to conclude that the stove will actually "boil" water faster at altitude but the water won't be as hot as boiling water at sea level.
Corwin C wrote:eamarquardt wrote:slowcowboy wrote:even if it just boils water like they said. it would be a aset to me.
There's a big difference in how wood (or any other fuel) burns at elevation. Just like anything else that consumes oxygen, there just isn't as much available per unit volume up here as at sea level. It cools the fire down quite a bit. I don't know if the actual flame temperature is different, but the time it takes to boil water (even though it boils at a lower temperature) is definitely much longer. Think of it as the opposite of what a blacksmith does in an abundance of fuel with the bellows, more oxygen (air), more heat ... less oxygen (air), less heat.
BTW - Anybody know how to put a set of bellows on Slow's Coleman stove?![]()
