of course I took maintenance and, necessary, repair into account when I made my statements. The additional goops and sealants that I spoke of was refering to something that might be done during assembly, at the factory, rather than re sealing as a part of general maintenance. We have a 1989 Layton fifth wheel, built as I described, with sticks and staples. It has held up well, but I do have to check things out periodically. I have had some water intrusion that I have had to address, but for being 23 years old and spending every day of it's life sitting outdoors, it's in fair shape. Additionally, as I stated, When, if ever, I get to my build, I will not be slapping it together as we did at Santa Fe. The cabinet maker in me will not allow it
len19070 wrote:Just "think like water" and try to shed it as you do your build.
Sounds like "DUH" advise but it does have merit.
afreegreek wrote:it's not water getting in that's the problem.. it's water that can't get out.. I read topic after topic on this site and it's all about sealing this and sealing that... I'm sure if I did a word search on here for breathing or ventilation I'd come up empty..
doug hodder wrote:I think I'll still make the efforts to keep the water from getting in to begin with.
Oldragbaggers wrote:doug hodder wrote:I think I'll still make the efforts to keep the water from getting in to begin with.
I'm with you Doug.
if you want to hear what I'm saying that's fine.. if you don't, it's no skin off my butt.. it's your trailer..
Hey Robbie
If you want to get by cheap you could use polyurethane diluted with mineral spirits for several coats on your sidewalls and end grains and then maybe several coats full strength.
