Mayne wrote:How thick an insulation would be used? I knw that 3/4" ply is shy of that spec, so.... would 1/2" foam insulation be used?
afreegreek wrote:you can get the same benefit, lower weight and room for insulation and wiring by just cutting strips of plywood or solid wood and glueing it around the perimeter, door and window openings, and attachment points.. using a full sheet and making a bunch of cutouts is a bit of a waste of wood and time.. some will argue that it is stronger but when the panel is already 10x stronger that is needed it's a bit of a stretch to split hairs that fine..
personally I'd go for thicker walls.. I have 1-1/2 inches of EPS insulation in my 18 foot trailer ...
As far as going with thicker walls, again, different strokes ...! Space is much more of a premium in a teardrop over a typical travel trailer, so even an inch-or-so of additional room in a given footprint can be a big deal (to some), and because there is so little room in a TD to begin with, it doesn't take much insulation to make a big difference (and certainly, even a little insulation is better than no insulation ...what is the benefit if doing it that way? What is the thickness of the material ...?
Oldragbaggers wrote:Heat gain/loss is not my biggest concern. Lance and I will not be camping in "cold weather". We are absolutely fair weather travelers. I am more concerned about condensation and sound, especially sound. Any sound dampening effects we can get from the insulation will be well worth the effort.
The question I have is what is the benefit if doing it that way.
We all bring different levels of experience and skill, plus familiarity with different materials and differing levels of creativity to the table. And teardrops are such a wonderful outlet to bring it all together and make it uniquely your own. The way each teardrop reflects the taste and personality, skill and experience of its owner is what makes them so much fun to build and to look at.
Oldragbaggers wrote:Thanks Danny. I didn't feel at all like you were directing your comments at me, I just wanted to point out the other aspects of deciding to insulate or not other than temperature.
I have to admit, I went back and forth several times on whether to insulate or not and whether or not I would make the same decision again is uncertain. I just went with my gut feeling and the experiences of others. So we'll see.
