So how big of an issue is water damage?
Postby CarlLaFong » Mon Dec 19, 2011 4:38 pm
There is always a ray of sunshine in every controversial thread. Rag bagger gets it.
Comparing a travel trailer to a boat is perfect. Keep the water off of the outside and the inside will take care of itself. We've trailer camped and traveled for 35, or so, years. We have never left the trailer sealed up for extended periods of time. If all of this moisture being expelled from our lungs and our pores was rotting away at the insides of our trailers, I would think that the cabinets and the upholstery would be taking the biggest hit, not the framing under the wall board or paneling. Seal up the outside, open a door or window from time to time or turn on the vent fan.
I wonder how much of this science was being pondered when I worked on the line at Santa Fe? Between junkies shooting up in the crapper, illegals jumping over the fence when "La Migra" showed up and the ex cons dodging their parole officers, I would suspect, not too often. :lol:
http://jkcallin.blogspot.com/
CarlLaFong
Images: 5
Postby LDK » Mon Dec 19, 2011 5:18 pm
Hey Robbie
By diluting the poly with mineral spirits it helps it to absorb deeper into the wood. Kinda like a poor mans version of cpes. Probably not as good as cpes but it's difinitely an alternative. I personally used a combination of stuff. I used cpes, 3m 4200, OSI micro gutter sealer, and butyl tape.
LDK
Postby afreegreek » Mon Dec 19, 2011 5:27 pm
CarlLaFong wrote:There is always a ray of sunshine in every controversial thread. Rag bagger gets it.
funny, I suggested using marine ply on a thread a few days ago and was told trailers and boats are not comparable... now in another thread they are and by the same person no less.. I think it's time for me to be a read only participant..
afreegreek
Postby angib » Mon Dec 19, 2011 6:27 pm
I like Mr Greek's word 'sealished'.
Where I used to work, we had a problem where water would migrate through a half-inch thick solid epoxy-glass laminate in the bottom of a racing yacht. The leak rate was mighty slow, but it existed.
angib
5000 Club
5000 Club
Images: 231
Postby CarlLaFong » Mon Dec 19, 2011 7:35 pm
Well, I went back a "couple" of days (30) and read all of my posts and I cannot find the one where I, allegedly, contradict myself. A little help here???
CarlLaFong
Images: 5
Postby afreegreek » Mon Dec 19, 2011 7:37 pm
sorry for sending you on the search.. it wasn't you..
afreegreek
Postby CarlLaFong » Mon Dec 19, 2011 7:58 pm
Good, 'cause I'm never wrong :lol:
CarlLaFong
Images: 5
