Defueling tools
Postby canned o minimum » Mon Dec 26, 2011 5:24 pm
You can afford SOAP ??
canned o minimum
Postby Mukilteo » Mon Dec 26, 2011 7:15 pm
Duh. It's just that bleach really cleans it.
Eric
Mukilteo
Images: 18
Postby eamarquardt » Mon Dec 26, 2011 8:00 pm
Mukilteo wrote:Duh. It's just that bleach really cleans it.
Bleach really clean my tea cups also.
Cheers,
Gus
eamarquardt
Images: 150
Postby Lazybones » Fri Dec 30, 2011 8:22 pm
I've been leaving the fuel in my lanterns. What's the reason for removing it?
Is it true? Is it necessary? Is it kind? Ask yourself these simple questions every time you are in doubt about any action.
Lazybones
Images: 49
Postby Wolffarmer » Fri Dec 30, 2011 8:35 pm
I'm with you LazyB
It is pretty well sealed up inside the font. Better than in a Coleman can in my opinion. And I have burned fuel from some very funky looking cans with no problem at all.
Randy
Wolffarmer
Images: 309
Postby doug hodder » Sat Dec 31, 2011 9:58 am
Lee...I've got a bunch that aren't going to be fired up for a quite a while...and I needed the fuel as I was out of it. Stoves hold a bunch and if it's got an old lead gasket seal in it and it looses any pressure...means it can loose fuel. Old stoves without top filler caps are a bit different than the typical Coleman stove. Sometimes you just gotta de-fuel one to work on it. Doug
Re: Defueling tools
Postby wagondude » Fri Jun 15, 2012 8:35 pm
Coleman fuel won't have all the gunk in it that gasoline does. It will get kind of gunky after a very long time where gasoline would in a matter of months. I fired up a stove that had just a splash of fuel that I am sure was more than 30 years old and it burned just fine, but there is still some gunk that needs to be cleaned out of the tank.
Bill
Bill
101137
wagondude
Images: 35
Re: Defueling tools
Postby Wolffarmer » Fri Jun 15, 2012 8:36 pm
I have burned fuel that I know was at least 20 years old. There are other things to worry about. As long as it is sealed good.
Randy
Wolffarmer
Images: 309
